Assembly trouble, stuck heater cartridge March 10, 2015 11:16PM |
Re: Assembly trouble, stuck heater cartridge March 11, 2015 07:09AM |
Re: Assembly trouble, stuck heater cartridge March 11, 2015 07:42AM |
droftarts
Support the heater block from underneath, for examble with the block on top of the jaws of a vice, so the heater cartridge is between the jaws, but not clamped, underneath. Then find an M5 bolt (the hole is 5mm, but the thread is just under this size, so will fit through cleanly), or use the M5 Z leadscrew, and use it as a drift to gently tap the heater cartridge out. Check the heater cartridge; it may just have a slightly raised area, you can probably gently sand it flat with sandpaper, and try fitting it again. Pass a 5mm drill through the heater block, to check it is the correct size.
Ian
RepRapPro tech support
Re: Assembly trouble, stuck heater cartridge March 11, 2015 11:46PM |
Re: Assembly trouble, stuck heater cartridge March 12, 2015 06:29AM |
Re: Assembly trouble, stuck heater cartridge March 12, 2015 06:39AM |
Re: Assembly trouble, stuck heater cartridge March 12, 2015 08:05AM |
droftarts
I think I would have probably pressed the heater cartridge into the heater block with the vice, but that's just me.
Re: Assembly trouble, stuck heater cartridge March 12, 2015 08:47AM |
Re: Assembly trouble, stuck heater cartridge March 12, 2015 08:54AM |
dmould
I wonder whether you could hold the heater in with some sort of fixative? I'm thinking of something like plaster of paris or a wall plaster repair substance such as pollyfilla, or even ordinary building cement (which seems to last OK in a brick fireplace).
Dave
Re: Assembly trouble, stuck heater cartridge March 12, 2015 09:22AM |
shadow651
dmould
Dave
I'd be concerned that anything like that might be fairly non-conductive and interfere with heat transfer to the heating block.... Idealy the cartridge should be in direct contact with the aluminum block.
Re: Assembly trouble, stuck heater cartridge March 12, 2015 11:36AM |
shadow651
The grub screw solution would probably work fine though, I should've thought of that. Would you recommend a flat tipped, pointed, or other shaped tip grub screw? Or does it not really matter?
Re: Assembly trouble, stuck heater cartridge March 12, 2015 12:22PM |
Re: Assembly trouble, stuck heater cartridge March 13, 2015 02:42AM |
Re: Assembly trouble, stuck heater cartridge March 13, 2015 05:52AM |
