ORMEROD 2 Beginners guide... Z-Cal March 15, 2015 08:42AM |
Re: ORMEROD 2 Beginners guide... Z-Cal March 15, 2015 10:08AM |
BenBB
*Layer height, I thought it was 0.1mm, not correct, if the nozzle is 0.5mm and you set slic3r to 0.1mm it turns out a mess... I started at 0.5mm and got some results
*Nozzle hole size, it is 0.5mm not 0.1mm.... if you set this wrong in SLIC3R you will either get to much or to little material.
*Print perimeters, are very important, you can let the printer do a couple of loops so that the head it nice and hot and the material is flowing freely....then you can start with the part
Hope this helps someone out there
I will post more as I go along and discover things the "hard way"
Tx Ben
Re: ORMEROD 2 Beginners guide... Z-Cal March 15, 2015 02:44PM |
Re: ORMEROD 2 Beginners guide... Z-Cal March 15, 2015 03:44PM |
BenBB
..what can you comment on the actual nozzel height from the bed.. initial printing. 0.1mm?? It seems to squash the material quite a bit...
Re: ORMEROD 2 Beginners guide... Z-Cal March 15, 2015 05:30PM |
Re: ORMEROD 2 Beginners guide... Z-Cal March 17, 2015 01:59AM |
Re: ORMEROD 2 Beginners guide... Z-Cal March 17, 2015 05:57AM |
Re: ORMEROD 2 Beginners guide... Z-Cal March 17, 2015 10:38AM |
Re: ORMEROD 2 Beginners guide... Z-Cal March 17, 2015 03:11PM |
OK here I`m a bit lost here, where do I enter these comp. values once I get them,Quote
Dave
Then enter the figures you read in your compensation command (the first corner will be 0, the other 3 corners will be the values you read)
Re: ORMEROD 2 Beginners guide... Z-Cal March 18, 2015 06:55AM |
Re: ORMEROD 2 Beginners guide... Z-Cal March 18, 2015 08:49AM |
BenBB
Dave
which command do I use
and do I do it manually in Pronterface,
or in the CONFIG.G file on the SD card ?
Ben
Re: ORMEROD 2 Beginners guide... Z-Cal March 18, 2015 02:46PM |
