The stresses of ABS March 21, 2015 01:58PM |
Re: The stresses of ABS March 21, 2015 04:05PM |
Europa
..After nearly an hour the bed had finally crept up to 98 degrees, the nozzle reaches the correct temperature..
It is as if the ability to print with ABS has been included just to bring it into line with other printers but in fact it is not capable of the task!
I would love to hear from other Ormerod users who have been successful
Re: The stresses of ABS March 21, 2015 04:17PM |
ormerod168
- and keep an eye on the x-runner while printing, this one is the first to go (slipping on bearing)..
Re: The stresses of ABS March 21, 2015 06:10PM |
Re: The stresses of ABS March 22, 2015 06:27AM |
Re: The stresses of ABS March 23, 2015 05:24AM |
Europa
I would love to hear from other Ormerod users who have been successful.
Re: The stresses of ABS March 23, 2015 09:09AM |
Re: The stresses of ABS March 23, 2015 10:54AM |
Sound advice. I will second. Although if you are in the UK you may have trouble buying it in large quantities as it is a controlled substance.Quote
dmould
Buy few litres of acetone - it has several uses with ABS.
Dave
Re: The stresses of ABS March 23, 2015 03:31PM |
jy_oc_hx
dmould
Dave
I have found it for sale at the pound shop near where i live in 150ml bottles.(£6.67/l)
Re: The stresses of ABS March 23, 2015 04:44PM |
Re: The stresses of ABS March 23, 2015 05:03PM |
dc42
Finally, I believe the power supply on the Ormerod 2 has a voltage adjustment potentiometer, near the low voltage end of the terminal block. You can turn it up to 13V or even a little higher to increase the heating power.
Re: The stresses of ABS March 23, 2015 05:17PM |
Re: The stresses of ABS March 23, 2015 08:10PM |
dc42
Buying anything but tiny bottles of acetone from retail stores in the UK is next to impossible now, but acetone can still be bought in reasonable quantities via eBay and other internet or mail order outlets. I guess the difference is that the security services can identify you as the purchaser.
Re: The stresses of ABS March 23, 2015 10:46PM |
dmould
dc42
You have made me curious, I wasn't aware that acetone was used in the production of anything nasty
Re: The stresses of ABS March 24, 2015 03:33AM |
Its reportable under the heading of "supplying explosives"! Link here. It is a bit over the top.Quote
shadow651
dmould
dc42
As far as I know acetone isn't a restricted substance in the United States (but if you bought a few hundred gallons you might get a call from the authorities). Although it is commonly used in chemistry labs, great for cleaning equipment and surfaces.
I can't really think of why it would be restricted. I mean, it's only mildly dangerous. Being flammable, and slightly toxic.... Plenty of other common household chemicals are just as or more dangerous (is isopropyl alcohol aka rubbing alcohol is almost exactly the same hazard, is that restricted?). I mean nail polish remover is typically pure acetone, sometimes with other additives. And gasoline is probably more dangerous.
Just seems kinda weird to me I guess... Not really sure how it could be used in a nefarious fashion.
Thanks. I'll give them a look.Quote
dmould
jy_oc_hx
dmould
Dave
I had no problem buying 3 X 5 litre cans in the UK recently - arrived within 3 days from here [www.cfsnet.co.uk] Less that £2/l
Re: The stresses of ABS March 24, 2015 04:39AM |
Re: The stresses of ABS March 24, 2015 05:02AM |
Europa
You can buy acetone in the form of cellulose thinners in almost every car accessory shop here in the UK, Halfords for example sell it in 1 and 1/2 litre tins.
Amazon has it in all sizes, a 5 litre tin will cost you £16.22 with free delivery!
It is certainly not a restricted substance in the UK.
Brian
Re: The stresses of ABS March 24, 2015 05:13AM |
jy_oc_hx
Re: The stresses of ABS March 24, 2015 09:28AM |
dc42
Sadly, it is not over the top. Explosives made from acetone and another widely-available substance were used by terrorists in 2005 to kill 52 people and injure another 700, in London.
Re: The stresses of ABS March 24, 2015 11:56AM |
Re: The stresses of ABS March 25, 2015 04:44AM |
dc42
jy_oc_hx
Re: The stresses of ABS March 25, 2015 05:20AM |
jy_oc_hx
dc42
jy_oc_hx
I wasn't meaning it was safety gone mad. What i was getting at was the fact that i couldn't even buy it from places where we have an account and trackable paper trace..
Re: The stresses of ABS March 25, 2015 09:25AM |
Re: The stresses of ABS March 25, 2015 09:33AM |
Re: The stresses of ABS March 25, 2015 09:53AM |
Re: The stresses of ABS March 25, 2015 10:40AM |
Re: The stresses of ABS March 25, 2015 01:17PM |
Re: The stresses of ABS March 25, 2015 03:06PM |
dc42
Does anyone have any suggestions on how to avoid stringing with ABS? I am finding it much worse than with PLA. I currently print at 235C hot end and 110C bed temperature. I tried reducing the hot end temperature, but at 230C it wasn't any better, and at 225C the extruder drive failed to push the filament through consistently. I guess I may need to check the dreaded "Avoid crossing perimeters" in slic3r.
Re: The stresses of ABS March 25, 2015 03:13PM |
Re: The stresses of ABS March 25, 2015 05:09PM |
dc42
Thanks Dave, I'll check the hot end temperature. Btw I am considering adding thermocouple support to my firmware fork - would anyone else be interested in using this?
