Homing problem April 08, 2015 06:26AM |
Re: Homing problem April 08, 2015 06:41AM |
Re: Homing problem April 08, 2015 06:45AM |
Re: Homing problem April 08, 2015 07:02AM |
Re: Homing problem April 08, 2015 07:16AM |
balak59
I will turn off the printer and checked if there is a swapped wire into the loom.
One question : In the Pronterface software, when i use the job Y+ , the bed must go toward the microswitch or forward ?
Re: Homing problem April 08, 2015 07:42AM |
Re: Homing problem April 08, 2015 07:51AM |
Re: Homing problem April 08, 2015 08:02AM |
Re: Homing problem April 08, 2015 09:23AM |
Re: Homing problem April 08, 2015 09:47AM |
Re: Homing problem April 08, 2015 09:55AM |
Re: Homing problem April 08, 2015 10:01AM |
balak59
OK, It's confirmed, When i prees on Y+the bed move to the left and to the right with the Y- button.
Re: Homing problem April 08, 2015 10:27AM |
dc42
That's the correct homeall.g file for an Ormerod 2. So I suggest you check the Y motor loom. By this, I mean check that the order of the coloured wires going into the connector at each and is the same as for the X or Z motor loom.
PS - if the loom is faulty and you don't want to correct it, you can reverse the direction with a command in config.g. I think the command you need is M569 P1 S0 but if that has no effect, try M569 P1 S1.
Re: Homing problem April 08, 2015 10:37AM |
Re: Homing problem April 08, 2015 11:11AM |
balak59
Of course after several tests, i need to type this command line after turning off my printer.
Is there a way to write this command line when i turn on the printer ?
