Web interface doesn't see my gcode layer changes April 17, 2015 12:47PM |
Re: Web interface doesn't see my gcode layer changes April 17, 2015 01:20PM |
Re: Web interface doesn't see my gcode layer changes April 17, 2015 01:53PM |
Re: Web interface doesn't see my gcode layer changes April 17, 2015 02:14PM |
Re: Web interface doesn't see my gcode layer changes April 17, 2015 02:28PM |
Re: Web interface doesn't see my gcode layer changes April 17, 2015 03:10PM |
Re: Web interface doesn't see my gcode layer changes April 17, 2015 03:21PM |
dc42
btw it has been reported to me that if you use absolute extrusion instead of relative extrusion, then the estimated end times are less accurate, because the firmware seems to start a new estimate every time a G92 E0 code is encountered (typically on each layer change).
Re: Web interface doesn't see my gcode layer changes April 17, 2015 03:25PM |
dc42
Re: Web interface doesn't see my gcode layer changes April 17, 2015 03:50PM |
zombiepantslol
dc42
Are you sure? I know Cura generates G92 E0 calls as soon as the filament usage reaches nearly 10000mm (AFAIR) but I have not seen any slicer that generates G92 calls after each layer change. Besides, my implementation relies on the raw filament usage (which shouldn't be affected by G92 calls anyway) so I can't see how this would mess with the final print estimations. But, of course, correct me if I'm wrong
Re: Web interface doesn't see my gcode layer changes April 17, 2015 03:59PM |
Re: Web interface doesn't see my gcode layer changes April 17, 2015 04:50PM |
Re: Web interface doesn't see my gcode layer changes April 17, 2015 06:56PM |
Re: Web interface doesn't see my gcode layer changes April 18, 2015 12:28AM |
Re: Web interface doesn't see my gcode layer changes April 18, 2015 08:35AM |
Re: Web interface doesn't see my gcode layer changes April 18, 2015 10:16AM |
Re: Web interface doesn't see my gcode layer changes April 20, 2015 08:14AM |
