Slic3r profile for Ormerod 2 results in rubbish prints April 27, 2015 08:22AM |
Re: Slic3r profile for Ormerod 2 results in rubbish prints April 27, 2015 08:36AM |
Re: Slic3r profile for Ormerod 2 results in rubbish prints April 27, 2015 01:31PM |
Re: Slic3r profile for Ormerod 2 results in rubbish prints April 27, 2015 01:45PM |
Re: Slic3r profile for Ormerod 2 results in rubbish prints April 27, 2015 02:29PM |
Re: Slic3r profile for Ormerod 2 results in rubbish prints April 27, 2015 03:00PM |
Re: Slic3r profile for Ormerod 2 results in rubbish prints April 27, 2015 03:14PM |
Re: Slic3r profile for Ormerod 2 results in rubbish prints April 27, 2015 04:33PM |
Re: Slic3r profile for Ormerod 2 results in rubbish prints April 27, 2015 04:49PM |
Re: Slic3r profile for Ormerod 2 results in rubbish prints April 28, 2015 09:05AM |
Re: Slic3r profile for Ormerod 2 results in rubbish prints April 29, 2015 10:48AM |
Re: Slic3r profile for Ormerod 2 results in rubbish prints April 29, 2015 11:14AM |
bartdietrich
Incidentally, Slic3er doesn't seem to recognize some perimeters as being external ones. For the Massive_Overhang_Test_Light, the distal perimeters of the two longer prongs print at normal fast speed and it's only those of the two shorter prongs that slow down (noticed this when I set external perimeter printing speed to rather low but left the other perimeter speeds high).
bartdietrich
Another issue I observed during infill printing: on a few occasions the printer crossed over its own trace on the same layer, i.e. something like a figure of 8. This obviously resulted in bumps which then caused problems and head crashes in the next layers. Although this might be an ooze/speed issue...
Re: Slic3r profile for Ormerod 2 results in rubbish prints April 29, 2015 01:05PM |
bartdietrich
... I'm having problems with Massive_Overhang_Test_Light (got this off the internet, don't know where it's been and what's in it)...
Re: Slic3r profile for Ormerod 2 results in rubbish prints April 29, 2015 03:49PM |
bartdietrich
The problem is that, after a few layers, the nozzle starts riding over and bumping into material it has already printed. After a sufficient number of layers this gets so bad that the nozzle either detaches the print from the bed and drags it around or gets stuck in parts of the print and makes the x,y motors skip.
Re: Slic3r profile for Ormerod 2 results in rubbish prints April 30, 2015 07:52AM |
gazoox
By the way: What about the Z heights 0,24 / 0,12mm. Why are those measures used instead of 0,10; 0,15; 0,2; 0,25 ? Are there technical reason for favouring? Should the other be avoid?
Re: Slic3r profile for Ormerod 2 results in rubbish prints May 01, 2015 11:07AM |
Re: Slic3r profile for Ormerod 2 results in rubbish prints May 01, 2015 11:34AM |
Re: Slic3r profile for Ormerod 2 results in rubbish prints May 01, 2015 11:46AM |
Re: Slic3r profile for Ormerod 2 results in rubbish prints May 01, 2015 12:48PM |
Re: Slic3r profile for Ormerod 2 results in rubbish prints May 01, 2015 02:12PM |
Re: Slic3r profile for Ormerod 2 results in rubbish prints May 01, 2015 02:51PM |
Re: Slic3r profile for Ormerod 2 results in rubbish prints May 01, 2015 03:36PM |
bartdietrich
Just realised: this bloody printer is starting to take over my life! :-)
Bart
Re: Slic3r profile for Ormerod 2 results in rubbish prints May 01, 2015 08:11PM |
As a temporary measure while you are printing a spool holder, just put the spool on a broomstick resting horizontally between a couple of piles of books, buckets, bricks or similar with something to stop the broomstick from rolling off.
How u mean entangled with the bed and X axis? X Axis will bend only slightly ,it will break or crack sooner since the acrylic is very fragile.
Just like me. Don't know if this is good or not. I do experiments since two month nearly every day. But this is my engineers nature eye rolling smiley
Re: Slic3r profile for Ormerod 2 results in rubbish prints May 01, 2015 08:24PM |
Re: Slic3r profile for Ormerod 2 results in rubbish prints May 02, 2015 08:25AM |
bartdietrich
I copied what settings there were in the supplied G code files into Slic3r and this resulted in immediate improvement of prints
(although also in a marked slowing down). You were right Dave, (much) slower printing speeds do make a big difference.
Although the massive overhang test is still a disaster (on the two most inclined prongs at least): no issue with the infill now, but with curling up. But I'll deal with this at some other point...
Oh, another thing. My x carriage was not completely level, it was leaning just a tiny tiny little bit forward. I was however unable to adjust this with the supplied 9 mm bearing/screw on the back of the carriage: it was at the far end of its adjustment range already. So I ordered some 10 mm bearings and will see if I can use those to position the head exactly level (starting at the other end of movement range for the adjustment screw obviously).
Re: Slic3r profile for Ormerod 2 results in rubbish prints May 02, 2015 08:41AM |
bartdietrich
Thanks Dave. I have books, I have one bucket, I can probably source some bricks (lots of building work around where I work) but I don't have a broom. I do have a mop though (goes with the bucket mentioned earlier). Thing is, cutting the mop handle to size (the printer shares a very limited space with lots of other kit) would mean I would become mop-less (for all practical purposes) and I don't like that idea. It's not that I like mopping, but sometimes you just gotta do what you gotta do. So therefore my mop stays untouched. I do like the general idea of taking an offensive weapon to it though.
Re: Slic3r profile for Ormerod 2 results in rubbish prints May 06, 2015 06:51AM |
Darathy
For a spoolholder i found this: [www.thingiverse.com] ,looks awsome!
Re: Slic3r profile for Ormerod 2 results in rubbish prints May 06, 2015 06:56AM |
ormerod168
yes, changing the bearing for a 10 mm was one of the first mods, another fix could be to glue a hacksaw to the x-axis plate as I did on ormerod1a
ormerod168
Agreed, being mop-less is the worst but use your imagination - small three outside house needs pruning? - blind man with white stick (easy pray, just chat them up so they cant here you hacking away) - drunken sailer with a wooden leg (watch them going round in circles, its a laugh!)
Re: Slic3r profile for Ormerod 2 results in rubbish prints May 06, 2015 01:42PM |
Re: Slic3r profile for Ormerod 2 results in rubbish prints May 06, 2015 02:56PM |
bartdietrich
Thanks for the input everyone!
Darathy
Does indeed look pretty cool! In the meantime, I designed my own (see photo). Nothing ground braking but functional. Am a bit concerned about the weight the triangular bit that holds the spool has to support now (the spool is sagging a tiny bit) but it's good enough for the time being.
gazoox
Hey Barddietrich.
The foil on your acrylic Ormerod parts should be removed. I made same mistake first, but then recognized that this is not part of the design
