where can I get the ormerod.ini of DC42 for slic3r?
Posted by sevenljy
April 30, 2015 09:27AM
Dear DC42,are you here?
I need your ini file for slic3r,which includes dual nozzle and simple nozzle.
Re: where can I get the ormerod.ini of DC42 for slic3r?
April 30, 2015 01:31PM
You can find myslic3r config bundle at [dl.dropboxusercontent.com].
Large delta printer [miscsolutions.wordpress.com], Robotdigg SCARA printer, Crane Quad and Ormerod
April 30, 2015 08:42PM
Thank you.PS:last time I get a problem with my EX board.Finally I fix it and it works well.Thank you!
July 25, 2017 02:11PM
Hi David
Where can I find the latest of these files?
This link does not work anymore.
dc42
December 06, 2018 04:11AM
Still nothing. sad smiley
December 06, 2018 07:58AM
Karoo Klong
Here you go - it's a bit dated, but so was the original request :-)
Erik
open | download - dc42 - Slic3r_config_bundle.ini (28 KB)
December 06, 2018 08:33AM
ormerod168
Karoo Klong
Erik
Thank you very much Erik.
I spent all of yesterday evening transfering all the Slic3r settings onto a speadsheet in order to compare different peoples settings.
I am contemplating sharing it so we all can share and compare.
December 06, 2018 03:40PM
ormerod168
Karoo Klong
Erik
Why is it that when I load these .ini files, the Filament diameter always shows up as 3mm on Slic3r?
I have Slic3r Prusa Edition 1.36.2-prusa3d-win64
December 08, 2018 03:29AM
Karoo Klong
ormerod168
Karoo Klong
Erik
Magic? - I don't know, haven't used Sli3er for a quite a while, uninstall, delete AppData/Application Data - reinstall maybe would help?
Erik
December 08, 2018 08:52AM
ormerod168
Karoo Klong
ormerod168
Karoo Klong
Erik
Erik
I did, Still same result.
What Slicer do you prefer?
December 08, 2018 03:01PM
Karoo Klong
ormerod168
Karoo Klong
ormerod168
Karoo Klong
Erik
Erik
Try on another PC or re-install windows :-) .... or manually edit the ini and take out all the 3mm stuff, that should do it!
Haven't used Cura and Slic3r for a long time so can't compare, I guess I prefer Simplify3D because it fills my needs and gives me no reason to look into other proggies - I invested in S3D because I got tired with the ever crashing Slic3r, new versions, new faults - guess it's much more stable now
Erik
December 12, 2018 02:34AM
Yes i must say since Prusa started developing their own branch of Slic3r it has improved significantly.
Could you perhaps share the settings for your Ormerod in Simplify 3D?
I have a friend that owns a copy and I would like to try it out on my printer to see how it works.
