Hot end fan suddenly slow to spin up May 06, 2015 03:47AM |
Re: Hot end fan suddenly slow to spin up May 06, 2015 04:36AM |
Re: Hot end fan suddenly slow to spin up May 06, 2015 05:16AM |
Re: Hot end fan suddenly slow to spin up May 06, 2015 07:13AM |
Re: Hot end fan suddenly slow to spin up May 06, 2015 07:36AM |
dmould
One other thing to check is whether the bolts holding the fan have warped its case, which can cause the fan blades to rub. My original fan had that issue and would not start unless I slackened the 2 mounting bolts a bit - but as they also hold the heatsink against the cold block I did not want to compromise the heat transfer by loosening too much and so bought another fan (MUCH quieter). I used RS part 758/8207 but there are plenty to choose from.
Dave
Re: Hot end fan suddenly slow to spin up May 06, 2015 07:41AM |
bartdietrich
WD40 is also a lubricant though. A major component of it by volume is a volatile solvent which evaporates quickly but this then leaves behind a non-volatile coating of lubricant.
Re: Hot end fan suddenly slow to spin up May 06, 2015 09:49AM |
David J
I don't agree... but it's not worth one second of arguing!
Re: Hot end fan suddenly slow to spin up May 06, 2015 10:10AM |
