Re: Z setting help May 15, 2015 02:49PM |
Re: Z setting help May 15, 2015 03:43PM |
Igloo_it
I used the repetier in the past with another printer and I can say that it's much better than the combination of slic3r + prontface. The first big difference is that I can move and rotate as I want with repetier
Re: Z setting help May 15, 2015 07:20PM |
Re: Z setting help May 16, 2015 03:32AM |
Igloo_it
the slic3r version is 1.1.7 and yes i never used the web interface due of the fact that i'm using a surface 3 pro that have no ethernet on board, i'll download the latest version of slic3r thank
Re: Z setting help May 16, 2015 03:56AM |
Re: Z setting help May 16, 2015 06:14AM |
Re: Z setting help May 16, 2015 06:25AM |
Re: Z setting help May 16, 2015 06:34AM |
Igloo_it
Thanks for the suggestion about the Ethernet connection. Could someone tell me some trick to improve the accuracy of the plane leveling, actually it's not accurate, one side (close to the z shaft) is ok but when go far from the x home the height of the hot end is not enough. Thanks
Re: Z setting help May 16, 2015 06:39AM |
Re: Z setting help May 16, 2015 06:40AM |
Re: Z setting help May 16, 2015 07:32AM |
Re: Z setting help May 16, 2015 07:39AM |
Re: Z setting help May 16, 2015 08:29AM |
