Web Control 1.06. stuck on layer 1 May 15, 2015 12:56PM |
Re: Web Control 1.06. stuck on layer 1 May 15, 2015 01:36PM |
Re: Web Control 1.06. stuck on layer 1 May 15, 2015 01:38PM |
Re: Web Control 1.06. stuck on layer 1 May 15, 2015 02:16PM |
Hi zplQuote
there is a known issue with the first layer height detection if your first layer is greater than or equal to 0.5mm. Can you share a sample G-code file?
Re: Web Control 1.06. stuck on layer 1 May 18, 2015 11:49AM |
Re: Web Control 1.06. stuck on layer 1 May 18, 2015 02:11PM |
It does stick and the raft works really well when printing ABS. This seems to me to be a default setting in Simplyfy3D when selecting a raft, I can't see where it can be adjusted. Unless someone can point me in the right direction. Thanks for accommodating the changes.Quote
zombiepantslol
I'm honestly surprised you manage to get the filament to stick when using a first layer height of 0.56mm. I wanted to increase the threshold to 0.55mm in my next fw release, but I'll rather go with 0.6mm now that I've seen your G-code Thanks again for sharing that excerpt!
Re: Web Control 1.06. stuck on layer 1 May 18, 2015 02:45PM |
zombiepantslol
Re: Web Control 1.06. stuck on layer 1 May 18, 2015 03:25PM |
