Can't get Arduino Duet to communicate May 24, 2015 09:01PM |
Re: Can't get Arduino Duet to communicate May 25, 2015 02:59AM |
Re: Can't get Arduino Duet to communicate May 25, 2015 06:02AM |
Re: Can't get Arduino Duet to communicate May 25, 2015 06:48AM |
Re: Can't get Arduino Duet to communicate May 26, 2015 03:46PM |
dc42
You can't flash the firmware with bossac until you have erased the firmware. But you should be able to communicate with the board using Arduino serial monitor. Make sure you have the line ending set correctly, and that you are typing in the G and M commands in upper case. As your board will be running old firmware, you will probably need to wait about 1 minute after power up before the board becomes responsive.
Re: Can't get Arduino Duet to communicate May 26, 2015 03:52PM |
robot_artist
dc42, what is the line ending and how do I set it correctly? I usually wait about 5 min and even after typing the G and M codes I still get no response in the Arduino serial monitor.
Re: Can't get Arduino Duet to communicate May 26, 2015 04:11PM |
dc42
robot_artist
It's at the bottom right of the Serial Monitor window, next to the baud rate. Set it to Newline.
