Homing problem August 04, 2015 03:46AM |
Re: Homing problem August 04, 2015 04:26AM |
Fpex
I have been forced to do an almost rebuilt of the ormerd2 due to cracks on the z axis plastics and supply + duet failure. Now I experience something I either did see in my first built or I totally forgot about. When homing the head crashes against the z axis and keeps pushing. Occasionally it will calibrate in the white spot nearby before crashing against the axis. Because I have a new duet, I am back to latest RRP firmware and not dc42 yet.
Re: Homing problem August 04, 2015 04:31AM |
Re: Homing problem August 04, 2015 04:32AM |
Re: Homing problem August 04, 2015 04:33AM |
Re: Homing problem August 04, 2015 06:47AM |
bgkdavis
Are you using orthogonal compensation?
I experienced similar problems, found there was something screwy with the homing.........I would be interested to know the results of this test
1) from startup home the X and Y axes in the order of XY and note the XY=0 position, if you haev calipers maybe measure the axes positions from a fixed point
2) turn off machine and repeat but in order YX
3) is there a visible or measurable difference between the two home positions?
4) remove the orthogonal compensation from your Config file and try again
Re: Homing problem August 04, 2015 06:50AM |
Re: Homing problem August 04, 2015 07:15AM |
Re: Homing problem August 04, 2015 07:30AM |
Re: Homing problem August 04, 2015 07:37AM |
Re: Homing problem August 06, 2015 04:10AM |
Re: Homing problem August 06, 2015 11:13AM |
Fpex
While homing works, the Z0 is now almost 2cm too high ....
Re: Homing problem August 06, 2015 12:05PM |
Re: Homing problem August 06, 2015 02:40PM |
Re: Homing problem August 06, 2015 05:23PM |
