PanelDue gets a facelift August 30, 2015 01:41PM |
Re: PanelDue gets a facelift August 31, 2015 01:02PM |
Re: PanelDue gets a facelift August 31, 2015 05:24PM |
ormerod168
Thank You much for Your time and effort - BTW, would it be possible to make the file sort order user changeable? - I prefer the WC Fields archive system :-)
Erik
Re: PanelDue gets a facelift September 01, 2015 02:18PM |
dc42
Sorry, I don't know what the "WC Fields archive system" is, despite have just researched his quotations. Would you care to explain? If you are thinking of sorting in date order, there are no file time stamps because the Duet does not have a real-time clock, and reading the sliced date from the file would take too long..
..But it occurs to me that the when uploading a file to SD card from the web interface, the browser could send the file time stamp across, and then the Duet firmware could time-stamp the file.
Re: PanelDue gets a facelift September 01, 2015 04:08PM |
dc42
Someone recently commented that the PanelDue screen had a 1980's look, and I could see his point. So I have given PanelDue a facelift in version 1.10 in an attempt to bring its appearance closer to the 21st century. I have about as much artistic ability as an amoeba with a hangover, so you may not like the result. Here are some sample screens on the 4.3 inch display:
If you can bear to look at it, you can find the binaries at [github.com] (follow the link to the version you want, then click Raw to download it). Suggestions for improving the colour scheme are welcome. I might even make the colours configurable.
Other changes in this release:
* Fixed a bug with deleting SD card files
* Added a permanent bed compensation/auto calibration button on the Control page to save you having to use up a macro for it.
* Now uses M408 status command instead of M105 (so needs 1.09 or later firmware; zpl's fork should work as well as mine)
Still to be done:
* Add subdirectory support for macros and gcode files
* Add support for a 3rd extruder (probably only on the 5 inch display)
* Add support for chamber heater control (probably only on the 5 inch display)
Re: PanelDue gets a facelift September 01, 2015 05:36PM |
Ababuy
[Now it looks like Windows 95!
Re: PanelDue gets a facelift September 02, 2015 07:08AM |
Re: PanelDue gets a facelift September 02, 2015 07:12AM |
Re: PanelDue gets a facelift September 02, 2015 09:22AM |
dmould
IMO it shouldn't be viewed as competing with a PC GUI, it is a machine control panel and should be compared with the controls of a washing machine, communications radio or aircraft/ship instruments etc. Anyway, even Microsoft has realised that the arty-farty screen gimmicks use resources that can lower the performance of what the system is actually used for (especially on battery-operated portable devices), and their latest OS has done away with most of the aesthetically nice but functionally useless fluff and we are back to the no-nonsense square panels. Just as clothes designs and hair length goes in and out of fashion in cycles, being 15 years out of date probably means that you are also 5 years ahead of the times!
Dave
Re: PanelDue gets a facelift September 02, 2015 03:05PM |
Re: PanelDue gets a facelift September 03, 2015 09:06AM |
Re: PanelDue gets a facelift September 03, 2015 09:18AM |
jamesarm97b
I was with someone configuring a Duet / PanelDue for the first time and we were looking over things. It wasn't connected to a printer yet but the question was that he did not see any type of Stop or Emergency Stop button, just the pause. Is there a button that would do something like Abort or Stop?
Re: PanelDue gets a facelift September 03, 2015 10:18AM |
jamesarm97b
...he did not see any type of Stop or Emergency Stop button, just the pause. Is there a button that would do something like Abort or Stop?
Re: PanelDue gets a facelift September 03, 2015 03:53PM |
