Re: New firmware 1.09i-dc42 September 21, 2015 11:41AM |
dc42
Are you sure it is the G28 on the slicer start gcode that is slow? I seem to remember that the original start gcode in the slic3r profile provided by RRP contained a G1 command without a feed rate in it, and this caused it to execute very slowly sometimes depending on what you did previously.
Re: New firmware 1.09i-dc42 September 21, 2015 12:13PM |
Re: New firmware 1.09i-dc42 September 22, 2015 07:38AM |
Re: New firmware 1.09i-dc42 September 22, 2015 07:51AM |
Re: New firmware 1.09i-dc42 September 22, 2015 08:39AM |
Re: New firmware 1.09i-dc42 September 22, 2015 09:41AM |
Re: New firmware 1.09i-dc42 September 23, 2015 01:32PM |
dc42
The homing buttons in the web interface do use the homing files. However, if you have a missing F parameter in homez.g then the movement speed will.depend on what commands have been executed previously. Also if you press the Home All button then it runs homeall.g and not homez.g.
Re: New firmware 1.09i-dc42 September 23, 2015 02:54PM |
Alex74
dc42
I've testet, Homing all via Web-Interface, Bed compensation via Web-Interface.
After that, I do G28 Z0 yeah, thats ist, it is slow.
Yes, you are right !
Thats it and now I finally think I understand what's going on.
The homez.g I'm using is the one you deliver with the firmware for ormerod2, it looks:
G91
G1 Z5 F200
G90
G1 X45 Y0
G30
G1 Z0 F200
So if I'm right, the G1 X45 Y0 uses the Speed F200 and this is really slow...
If I change it to G1 X45 Y0 F2000 it will be fast, or not (At the moment I can't test it) ?
Thanks a lot for all your work and your patience to explaine !
