Anything else? September 09, 2015 07:40AM |
Re: Anything else? September 09, 2015 09:29AM |
Re: Anything else? September 09, 2015 10:15AM |
dc42
...Are you certain that you really do have a warp in the bed? If the problem is that with 3-point levelling you can't get all 4 corners at the same height, that indicates that you have a slight twist between the Y axis parallel rods. You can eliminate that by loosening the attachment screws at one end of the Y axis and moving the outer end of one end plate up or down relative to the other.
Re: Anything else? September 09, 2015 12:21PM |
bananaman
...I notice the X-arm extruder clip has a crack so I'll need to print another. Tensioned extruder?..
I do need to move it about a little on its bench at times and have had a few connectors move off the pins a bit too easily. Gave me some weirdness until I found the issue..
..Anything else I should look at or watch out for?..
Re: Anything else? September 09, 2015 06:01PM |
Re: Anything else? September 13, 2015 05:35PM |
Re: Anything else? September 13, 2015 06:41PM |
bananaman
DC42, do you still produce the Zaxis prob fan controller mod?
Re: Anything else? September 14, 2015 12:51PM |
Re: Anything else? September 14, 2015 09:00PM |
Re: Anything else? September 15, 2015 08:03AM |
Darathy
why is a long brass Z nut better then the original nut?
Re: Anything else? September 15, 2015 01:34PM |
dmould
Darathy
It causes less wear on the Z screw. If you have bed compensation enabled, the Z screw takes a huge hammering, and several people have had stripped threads. The long nut distributes the load over more threads, and brass against steel causes less wear.
If you do not use bed compensation it is not so critical because the Z screw only moves once per layer.
Dave
Re: Anything else? September 15, 2015 01:48PM |
Re: Anything else? September 15, 2015 03:01PM |
Re: Anything else? September 15, 2015 03:58PM |
Re: Anything else? September 15, 2015 06:58PM |
