First layers problem September 09, 2015 11:12AM |
Re: First layers problem September 09, 2015 11:24AM |
Re: First layers problem September 09, 2015 01:10PM |
Re: First layers problem September 09, 2015 02:02PM |
helidave1
The skirt prints and looks good but It never goes completely around the object. There is always quite a significant gap
Re: First layers problem September 09, 2015 02:46PM |
Re: First layers problem September 09, 2015 03:18PM |
Re: First layers problem September 09, 2015 03:21PM |
Re: First layers problem September 09, 2015 03:37PM |
Re: First layers problem September 09, 2015 03:38PM |
helidave1
I rechecked the bed again as per the instructions and it looks fine. If I alter the skirt value from 1 to 3 in slic3r I get the result shown in the photo....
Re: First layers problem September 09, 2015 03:50PM |
Re: First layers problem September 09, 2015 03:51PM |
Re: First layers problem September 09, 2015 04:52PM |
Re: First layers problem September 09, 2015 05:20PM |
Re: First layers problem September 09, 2015 06:15PM |
Re: First layers problem September 09, 2015 08:10PM |
Re: First layers problem September 10, 2015 05:53AM |
Re: First layers problem September 10, 2015 11:58AM |
Re: First layers problem September 10, 2015 12:53PM |
dmould
Don't use a Z offset, just ensure that the Z axis has been correctly zeroed. After homing in the way you usually do, heat the bed to its normal print temperature but leave the nozzle cold, raise the nozzle to around 5mm, put a sheet of A4 paper on the bed and send the command
"G1 X100 Y100 Z0"
Check that the paper is gripped firmly but can be pushed and pulled with some resistance. Hold the paper by the edge and ensure you are not pushing down on the bed. If it is not right,move the Z height in very small steps (0.05mm or 0.1mm) using the web or Pronterface buttons, and when it is right send "G92 Z0" Then send your print file in the normal way. NOTE - ensure the print file does not include any homing commands at the start.
IMPORTANT - before homing or checking as described, make sure that the nozzle is clean. A small blob of plastic on the nozzle will cause you to set the Z zero height far too high.
Dave
Re: First layers problem September 10, 2015 03:45PM |
Re: First layers problem October 01, 2015 03:18PM |
Re: First layers problem October 01, 2015 03:47PM |
Re: First layers problem October 02, 2015 07:25AM |
Ecko
I have recently started having the same problems - my prints were ok on objects with a small surface area nut i cant print larger models.
i am getting the same high extruder results as ormerod 168. I run the G92 Z0 command with the print head just touching the glass bed, I run the print and the first layer is being printed at 0.36 - but the first layer did not "squish" as it did previosly... I got my printer working properly 2 weeks ago and have only recently encountered this problem.
My gcode has a G28 Z0 command near the start, but should that not take the z probe to my decided z0 value? or does it override the z0 value and set it to default?
Re: First layers problem October 02, 2015 12:35PM |
Re: First layers problem October 02, 2015 05:18PM |
Re: First layers problem October 03, 2015 02:17AM |
Re: First layers problem October 05, 2015 10:43AM |
Re: First layers problem October 05, 2015 01:20PM |
Ecko
Happy to say removing g28 z0 from the gcode worked. But I do wonder - if I have just set zero by sending g92 z0 to the duet - why does it seem yo ignore my zero reading and default to a standard reading every time I run the bed compensation (I am using zpl 1.6 web interface). Anyway it works - yay.
Re: First layers problem October 05, 2015 01:26PM |
Darathy
Ecko
I seem to have the same issue ,i home my Z so it catches a peice of paper under the nozzle , then i run bed compensation(5 point with DCs sensor) and send G1 Z0 and nozzle does not catch the paper again.
Re: First layers problem October 05, 2015 02:37PM |
Re: First layers problem October 05, 2015 03:25PM |
