Ormerod stopped working----help!!!! -- resolved October 07, 2015 06:03AM |
Re: Ormerod stopped working----help!!!! October 07, 2015 08:57AM |
appjaws1
I switched on this morning and could not connect via the web browser but the error page says "This web page is not available,ERR_CONNECTION_REFUSED" , tried Pronterface and the temps are showing correct when cold.
If I switch on the main 12 volt power, I can move all three axis and heat the bed but the hot end is just not heating, occasionally the red light on the duet flashes and the amber light on dc42's board flashes.
I have not made any changes since it was working yesterday, I am using dc42's probe, single hot end board, with the 2 beam sensor and have checked that I do not have 12 volts on the heater connection.
So it appears that the duet is not providing 12 volts to the heaters but I don't know why.
I have also connected a spare duet and the symptoms are the same.
What do I check next?
appjaws1
@dc42 Dave can my dual hot end board be used as a single hot end, without the second hot end being connected?
If you are using a dual-nozzle board on a single-nozzle machine and your board does not have the jumper pins next to the thermistor 1 connector, when attaching crimp pins to the thermistor wires you must also crimp one end of a short loop of wire into the left hand pin. The other end of this wire goes to the left hand pin in another 2-pin receptacle, which will be plugged in to the Thermistor 2 connector on the board.
Re: Ormerod stopped working----help!!!! October 07, 2015 10:58AM |
Re: Ormerod stopped working----help!!!! October 07, 2015 11:52AM |
Re: Ormerod stopped working----help!!!! October 07, 2015 12:28PM |
Re: Ormerod stopped working----help!!!! October 07, 2015 12:46PM |
appjaws1
Thank you Dave, I'll try that.
The good news is that the printer is now printing using Pronterface.
Still can't connect with the web interface.
Tried arp -d but it failed as you quite rightly said it requires elevation.----How do I do that?
Re: Ormerod stopped working----help!!!! October 07, 2015 01:36PM |
Re: Ormerod stopped working----help!!!!---resolved October 07, 2015 02:28PM |
Re: Ormerod stopped working----help!!!! October 08, 2015 01:09AM |
Re: Ormerod stopped working----help!!!! October 08, 2015 04:49PM |
Re: Ormerod stopped working----help!!!! October 09, 2015 02:28PM |
Re: Ormerod stopped working----help!!!! October 09, 2015 05:33PM |
dmould
Or simply power-cycling the router.
Re: Ormerod stopped working----help!!!! October 12, 2015 06:41AM |
Treito
dmould
In that case you have a bad router. My router keeps the IP-addresses for several weeks if possible.
Re: Ormerod stopped working----help!!!! -- resolved October 12, 2015 08:31AM |
Re: Ormerod stopped working----help!!!! October 12, 2015 02:46PM |
dmould
Treito
dmould
It doesn't make it a bad router. There is not usually a great deal of advantage in putting the leasing table into non-volatile storage, and having too many "sticky" variables can itself cause problems because it means that when something goes wrong due to a misconfiguration, a power cycle does not fix the issue. "Sticky" Arp tables are a nightmare on a system where IP addresses are frequently re-allocated to different devices.
The PC itself usually retains its last DHCP address, and will request the same address in its following network boot or lease renewal, which will be granted if the subnet address is correct and that address has not been leased to another device, so even if the router does not retain its lease table many devices will nevertheless keep the same IP address. Port-forwarding is these days associated with MAC addresses rather than IP addresses, so ports will be forwarded to the same PC even if its local IP address has changed.
Dave
Re: Ormerod stopped working----help!!!! October 13, 2015 07:05AM |
Treito
You cannot ensure that if the power returns all consumables are ready such as PCs or printers. To ensure all get the right IP back the router should store these IPs for at least one or two weeks before any other consumer can take the IP-address. That is my opinion.
