Replacement motor October 15, 2015 02:19AM |
Re: Replacement motor October 15, 2015 02:46AM |
Re: Replacement motor October 15, 2015 03:13AM |
Re: Replacement motor October 15, 2015 03:51AM |
Re: Replacement motor October 15, 2015 04:27AM |
Re: Replacement motor October 15, 2015 06:50AM |
Re: Replacement motor October 15, 2015 07:22AM |
Joar107
When you run the bed on AC main do you use the 12V that you normaly connet to the heated bed to run a relay as this one link ?
And the the thermistor is connected as usually of course?
/Joar
Re: Replacement motor October 15, 2015 07:39AM |
Think of me like a child that know nothingQuote
dmould
Joar107
/Joar
No, you don't need a timer relay - any relay with a 12V coil and mains rated N.O. contacts can be used - connect the coil to the bed heater output of the Duet (e.g. [uk.rs-online.com]). Don't forget to put a flyback diode across the relay coil.
The thermistor stays exactly the same.
Dave
Re: Replacement motor October 15, 2015 07:41AM |
Hi Sven what torque do you have on that one?Quote
Treito
Hello,
I use motors with 34mm depth and 1.5A for my Ormerod 2. I am at the office right now, but if you are interested I can provide a datasheet within the next 8-10 hours. These motors are very common at ebay and Aliexpress ans so the price is less then 15€. The original motors are hard to get so I decided to use these ones. I was astonished that they can operate with 1.5A. I tested that already and it works. Maybe the torque is less than your motor, but it is more than the original as I compared both motors.
Regards,
Sven
Re: Replacement motor October 15, 2015 08:13AM |
Joar107
The flyback diod puzzles me could you explain a little bit more.
Thanks /Joar
Re: Replacement motor October 15, 2015 09:08AM |
Excellent Thanks, this will happen, this is so much better than schoolQuote
dmould
Joar107
Thanks /Joar
When voltage is removed from an electromagnet (such as the coil of a relay), the sudden drop in magnetic field will induce a very high voltage across the coil. This can blow a semiconductor such as the switching FET on the Duet. The induced voltage is however of the opposite polarity to the original energising voltage, so it can be shorted out by connecting a diode across the relay that conducts when the voltage is reversed. In this case one side of the coil will be connected directly to +12V, and the other side to the bed heater output of the Duet, so you connect a diode straight across the coil with the cathode of the diode connected to the +12V side of the coil. (The cathode is the end of the diode that is marked). A suitable diode would be a 1N4005 (e.g. [uk.rs-online.com]). Make very sure it is the right way around otherwise it will short out the coil when energised (which will draw excessive current and also blow the FET!)
A side-effect is that the current through the diode slows down the decay of the magnetic field, which means that the relay remains on for a while (there is a small time-delay after coil voltage is removed before the relay contacts open). In this application the short delay will not cause problems, but in other applications where the relay must open immediately, other arrangements have to be made for dealing with the flyback voltage.
Dave
Re: Replacement motor October 15, 2015 12:54PM |
Re: Replacement motor October 16, 2015 02:47AM |
Could you give me a link to a product that would suit my needs.Quote
dc42
Don't put heatsinks on the stepper drivers, they are not effective because the driver chips are designed to be cooled via the PCB. Position the fan to blow air over both sides of the PCB, along the line of driver chips.
I would never use a mechanical relay to switch a mains voltage heated bed. DC-AC SSRs are inexpensive, reliable, don't generate interference, don't need flyback diodes, and can even be used with slow PWM. They generally work with anything between 3V and 32V on the control input. Mine is connected to the heated bed output terminal block.
My main motivation for changing to 24V was to get higher maximum speeds after changing to 0.9deg/step motors on my delta printer. A more common reason for using 24V is to drive a larger heated bed without using AC mains voltage.
Re: Replacement motor October 16, 2015 04:08AM |
Joar107
dc42
Thanks /Joar
Re: Replacement motor October 16, 2015 12:00PM |
Re: Replacement motor November 25, 2015 08:24AM |
