Bowden Tube Clip broken at Extruder- Wheres the STL file? January 05, 2016 08:50AM |
Re: Bowden Tube Clip broken at Extruder- Wheres the STL file? January 05, 2016 10:35AM |
Re: Bowden Tube Clip broken at Extruder- Wheres the STL file? January 05, 2016 11:20AM |
tig124
..Has this happened to anyone previously?
- Really urgently need this resolving as urgently need to get a new lower z axis mount (More splits have occurred!).
Seriously beginning to question the capabilities of the Ormerod!
Re: Bowden Tube Clip broken at Extruder- Wheres the STL file? January 05, 2016 01:26PM |
Re: Bowden Tube Clip broken at Extruder- Wheres the STL file? January 05, 2016 01:31PM |
Re: Bowden Tube Clip broken at Extruder- Wheres the STL file? January 05, 2016 01:37PM |
Re: Bowden Tube Clip broken at Extruder- Wheres the STL file? January 05, 2016 01:48PM |
Re: Bowden Tube Clip broken at Extruder- Wheres the STL file? January 05, 2016 02:47PM |
Re: Bowden Tube Clip broken at Extruder- Wheres the STL file? January 05, 2016 05:16PM |
ormerod168
tig124
Not broken Clip but the bowden tube got unscrewed, the cause was the brass bit was able to turn in the extruder even with the clip in place, must have been more filament pushed in the +X direction (brass bit did not turn under pressure) than in the -X direction (brass bit able to turn)
[attachment 69005 bowden_cable_fail.JPG]
Re: Bowden Tube Clip broken at Extruder- Wheres the STL file? January 06, 2016 05:13AM |
Re: Bowden Tube Clip broken at Extruder- Wheres the STL file? January 06, 2016 05:14AM |
Re: Bowden Tube Clip broken at Extruder- Wheres the STL file? January 06, 2016 06:50AM |
tig124
Have considered replacing the lower Z mount with a machined plastic part to provide more strength.
Re: Bowden Tube Clip broken at Extruder- Wheres the STL file? January 06, 2016 09:40AM |
ormerod168
tig124
..or you could bolt the extrusions together, then the Z lower mount only have to hold the smooth rod
[attachment 69049 y-z-extrusion-fusion.JPG]
[attachment 69050 ormerod_downunder.JPG]
Erik
Re: Bowden Tube Clip broken at Extruder- Wheres the STL file? January 06, 2016 05:47PM |
Re: Bowden Tube Clip broken at Extruder- Wheres the STL file? January 10, 2016 02:07PM |
0x0000
...What materials did you use for the Y-ends..
...and what is the stuff at the bottom of the printer... looks like 5mm aluminium and maybe some steel along the bottom?
It looks like the old acrylic is still in there holding the rods...
did you have to modify the Y-idler and Y-motor mount to get the extra metal in there?
Can you print upside down?
