To scour the internet for dual ormerod hotends or buy something in stock... January 10, 2016 07:13AM |
Re: To scour the internet for dual ormerod hotends or buy something in stock... January 10, 2016 07:55AM |
Re: To scour the internet for dual ormerod hotends or buy something in stock... January 10, 2016 08:01AM |
Re: To scour the internet for dual ormerod hotends or buy something in stock... January 10, 2016 08:48AM |
Re: To scour the internet for dual ormerod hotends or buy something in stock... January 10, 2016 09:03AM |
Darathy
I had at the start of each layer there would be a blob and circles werent all that good ,inner part of a tube would not stick to previous layer so i would get strings all over the inside like this( i have cut most with a knife but couldnt more):
[attachment 69396 IMAG0377.jpg]
The same part with original hot end was perfect.
Altho another user Treito has good results even in circles but he has a fake.
Re: To scour the internet for dual ormerod hotends or buy something in stock... January 10, 2016 09:25AM |
Re: To scour the internet for dual ormerod hotends or buy something in stock... January 10, 2016 11:28AM |
Did you have any cooling fan over the build area during this?Quote
Darathy
[attachment 69396 IMAG0377.jpg].
What did you set your rectraction speed to? I have set slic3r's retraction distance up to 7mm and the same speed however it still makes a blob where it lifts up to the next layer. At the price they are demanding i find it valid to call S3D an investment, do you find it worth it?Quote
dougal1957
Both myself and DC42 IIRC did have that blobbing effect and I got rid of it by increasing retraction amount and speed I also set slice to do inner before outer perimeters and set the start point to be the same whilst this reduced the effect it didn't go completely until I switched to S3D and that cured the issue completely.
Re: To scour the internet for dual ormerod hotends or buy something in stock... January 10, 2016 12:15PM |
improprietary
Darathy
dougal1957
Re: To scour the internet for dual ormerod hotends or buy something in stock... January 10, 2016 01:17PM |
improprietary
Darathy
dougal1957
Re: To scour the internet for dual ormerod hotends or buy something in stock... January 10, 2016 07:39PM |
Re: To scour the internet for dual ormerod hotends or buy something in stock... January 11, 2016 02:08AM |
... y'know that 45mm/s thing explains a bit. Spashiba.Quote
Treito
At the moment I use no additional fan and even bridging works really good. After finetuning the parameters in Simplify3D I get better results than using the original nozzle. I use a retract of 4.5mm with 40mm/s speed. Printing speeds higher than 45mm/s start causing artefacts caused by the general design of the printer. The costs of only 6€ for a fake nozzle should be worth testing it.
Re: To scour the internet for dual ormerod hotends or buy something in stock... January 11, 2016 03:34AM |
Re: To scour the internet for dual ormerod hotends or buy something in stock... January 11, 2016 08:41AM |
Re: To scour the internet for dual ormerod hotends or buy something in stock... January 11, 2016 08:47AM |
Re: To scour the internet for dual ormerod hotends or buy something in stock... January 11, 2016 10:44AM |
