Re: Need Help: Error reading file February 01, 2016 04:56PM |
Re: Need Help: Error reading file February 01, 2016 05:00PM |
Re: Need Help: Error reading file February 02, 2016 03:07AM |
Re: Need Help: Error reading file February 02, 2016 03:13AM |
Re: Need Help: Error reading file February 02, 2016 03:16AM |
Re: Need Help: Error reading file February 02, 2016 03:24AM |
Re: Need Help: Error reading file February 02, 2016 03:28AM |
Re: Need Help: Error reading file February 02, 2016 04:47AM |
Re: Need Help: Error reading file February 02, 2016 01:23PM |
Re: Need Help: Error reading file February 02, 2016 06:01PM |
Re: Need Help: Error reading file February 03, 2016 03:01AM |
Re: Need Help: Error reading file February 03, 2016 08:29AM |
You could maybe do a "dry run" with both bed and hotend turned off and no filament loaded, and if that works do the same run with the bed turned on to see if it might be the culprit.Quote
Fpex
Is there way to change the modulation of the heating (bed or hot end) via config.g to reduce current consumption. I want to check if my problem is related maybe to a weak supply.
Re: Need Help: Error reading file February 03, 2016 09:07AM |
Re: Need Help: Error reading file February 03, 2016 09:43AM |
Fpex
I am going to try a run with bed off.
If this fails, I will try to remove the external 12/5v board (since it gets rather hot).
If this fails, i will try to use a different supply.
If this fails, I try to wire a duet 0,8,5 instead of the current 0.6
Ig this also fails, .... no clue.
But all signs indicate a supply problem as a dip in supply on USB and SD reader could explain the pronterface failure and the sudden EOF indicated by the firmware. The problem is to figure it our what is going on.
Re: Need Help: Error reading file February 03, 2016 09:54AM |
Re: Need Help: Error reading file February 03, 2016 10:52AM |
Re: Need Help: Error reading file February 03, 2016 11:12AM |
Re: Need Help: Error reading file February 03, 2016 11:49AM |
Fpex
..Any idea how to get cura producing correct code ?
Re: Need Help: Error reading file February 03, 2016 02:54PM |
Re: Need Help: Error reading file February 03, 2016 03:05PM |
Re: Need Help: Error reading file February 03, 2016 03:31PM |
Re: Need Help: Error reading file February 03, 2016 03:56PM |
Re: Need Help: Error reading file February 03, 2016 04:33PM |
Re: Need Help: Error reading file February 03, 2016 05:24PM |
Re: Need Help: Error reading file February 04, 2016 02:41AM |
Re: Need Help: Error reading file February 04, 2016 03:42AM |
Re: Need Help: Error reading file February 04, 2016 04:15AM |
Re: Need Help: Error reading file February 04, 2016 07:27AM |
Re: Need Help: Error reading file February 04, 2016 07:31AM |
