new printer problems [prusa i3] (print head wont feed) January 22, 2016 07:28AM |
Re: new printer problems [prusa i3] (print head wont feed) January 23, 2016 05:37AM |
Re: new printer problems [prusa i3] (print head wont feed) January 23, 2016 10:32PM |
Re: new printer problems [prusa i3] (print head wont feed) January 24, 2016 12:41AM |
Re: new printer problems [prusa i3] (print head wont feed) January 25, 2016 10:40AM |
Re: new printer problems [prusa i3] (print head wont feed) January 25, 2016 07:14PM |
Re: new printer problems [prusa i3] (print head wont feed) January 25, 2016 07:37PM |
Re: new printer problems [prusa i3] (print head wont feed) January 25, 2016 11:36PM |
Re: new printer problems [prusa i3] (print head wont feed) January 26, 2016 07:47AM |
adexin
dave, i tried changing M82 to M83 in the start code just now and it made a difference although it still did not work, i had all the same traits, but with this time it slowly speed up over time
Re: new printer problems [prusa i3] (print head wont feed) January 28, 2016 12:10AM |
Re: new printer problems [prusa i3] (print head wont feed) January 28, 2016 01:30AM |
Re: new printer problems [prusa i3] (print head wont feed) January 28, 2016 08:21AM |
adexin
ok, so trying to run the example G-code files yield the same results( extruder did not work)
tried plugging extruder into the "X" axis controller port and using the built in move function would move as expected given setup, (proper turning when input receved, locked when not turning, ect) so yea that worked
Re: new printer problems [prusa i3] (print head wont feed) January 28, 2016 07:41PM |
dmould
adexin
In that case try plugging the X or Y axis motor into the extruder output. If that has a problem it would indicate a faulty stepper driver chip. You will need to enable cold extrusion to be able to operate the extruder when the nozzle is cold, and also ensure that the correct tool is selected.
Dave
