Suitable fan for part cooling using Ormerod 528.5 duct and Duet 0.6 February 01, 2016 08:33AM |
Re: Suitable fan for part cooling using Ormerod 528.5 duct and Duet 0.6 February 01, 2016 01:17PM |
orictosh
Wiring is as follows
fan's black wire goes to the source on the mosfet
fan's red wire goes to the fan 0 positive connection on the duet board
fan's brown wire goes to the drain on the mosfet
mosfet's gate goes to the negative pin on the fan 0 connection
The mosfet's source conections go to a gound pin on the duet (it's the left pin above the hot end fan connection)
The set of pins is called J6
Re: Suitable fan for part cooling using Ormerod 528.5 duct and Duet 0.6 February 01, 2016 02:35PM |
Re: Suitable fan for part cooling using Ormerod 528.5 duct and Duet 0.6 February 01, 2016 09:01PM |
Darathy
I use this fan: [www.ebay.co.uk]
and use a 2N7000 mosfet wired like this:
orictosh
But since its a PWM fan it will never stop spining completely at 0% it will still spin at abaut 30% speed but it wont have any bad effect on pla ,you might have a problem with ABS though.
