Clogged nozzle just won't clear March 12, 2016 05:25AM |
Re: Clogged nozzle just won't clear March 12, 2016 06:58AM |
Re: Clogged nozzle just won't clear March 12, 2016 07:55AM |
static65
What's the next step? I saw a post on using a heat gun and compressed air to clean a quick-set nozzle, but I don't have any air tools (also it's an Ormerod 1 so not quick-set). I've ordered some 0.5mm drill bits to see if I can clear it from the other side but not sure if that's a good idea.
By this point I would normally have bought a new nozzle but I can't find any non-quick set ones available. Might be time to get a printer that still has support...
Re: Clogged nozzle just won't clear March 12, 2016 09:27AM |
Re: Clogged nozzle just won't clear March 12, 2016 11:26AM |
Re: Clogged nozzle just won't clear March 12, 2016 02:22PM |
ormerod168
static65
[attachment 74408 one-piece-nozzle.JPG]
1) clear the first part with a 3mm drill bit, hand held so you can feel the drill bit follow the path of the hole without damaging the inner surface of the nozzle
2) clear the second part with a 2mm drill bit, same procedure
3) clear the 0,5mm hole, notice this part is only 0.5mm deep so you should be able to push that out even while cold, e.g pull a single wire form a wire brush, these are usually 0.4mm thick and very stiff, fingerspitzgefühl is important at this point, do not damage the the tip of the nozzle
3a) heat the nozzle with a heat gun, suck the last D0.5x0.5mm out with a "spring-loaded-solder-sucking-thingie" whatever its called :-)
3b) heat the nozzle and blow the last part out with a spring loaded or pre-charged pneumatic air gun
You can get a 0.3mm one-piece-nozzle at emakershop here...
[www.emakershop.com]
..and you have ordered a 0.5mm drill already so should not be a problem
Erik
Re: Clogged nozzle just won't clear March 13, 2016 01:26AM |
Re: Clogged nozzle just won't clear March 13, 2016 01:52AM |
Re: Clogged nozzle just won't clear March 13, 2016 03:24AM |
static65
I had to look up a translation for "fingerspitzgefühl" but other than that your instructions were most excellent
Re: Clogged nozzle just won't clear March 13, 2016 06:17AM |
Re: Clogged nozzle just won't clear March 13, 2016 07:59AM |
