Temperature problems April 29, 2016 09:37PM |
Re: Temperature problems April 30, 2016 12:26AM |
Re: Temperature problems April 30, 2016 01:48AM |
Re: Temperature problems April 30, 2016 02:20AM |
Re: Temperature problems April 30, 2016 10:31AM |
0x0000
I believe the firmware will stop extruding once the temperature hits 160 to prevent damage to the hotend. Since 170 is quite close to that, maybe it's briefly dipping below the cutoff temperature? This can be overridden by enabling "cold" extrusions with the M302 command, though that's usually only done during maintenance.
achaz
Is the measured temp actually dropping under 170? If so, do you have a part cooling fan that might be cooling the heating block?
Treito
How did you calculate the optimal temperature? Normally this is done by a test print.
Re: Temperature problems April 30, 2016 01:26PM |
Re: Temperature problems April 30, 2016 01:30PM |
Re: Temperature problems April 30, 2016 02:12PM |
Re: Temperature problems April 30, 2016 02:59PM |
dc42
Are you really certain that the relationship ship between the displayed and actual temperature is changing? That is not impossible if your Duet or thermistor is faulty, but is certainly unusual. Can you check using a multimeter with thermocouple probe? Are the thermistor leads secured so that the thermistor cannot move within the heater block?
I've tried securing it with kapton tape, but it just falls off. |
Re: Temperature problems May 03, 2016 07:56AM |
