I self built an Ormerod 2 printer. In the processes I ordered to 100k thermistors missing the fact the bed was a 10k thermistor. I did not think it mattered, but it seems to as the Duet electronics reads the bed at -19. However, when I plug it into the hot head temp monitor it reads correctly.
I am running 1.14 dc42 firmware (just started commisioning the unit tonight). Is there a way I can tell the Duet to use the 2nd temp monitor for the bed temp? Or is there a place I can adjust or recompile a file to get it to work with the 100k thermistor? I assume the bed temp monitor is working because when I remove the wire it reads (I think) -64 (what ever it was, it was different then when it is plugged in).
