ormerod firmware 078c
August 17, 2016 03:31AM
I used the 3d printer first time.
ormerod was my best choice.
I download the firmware from github, but it can not compiled successfully.
i try to change the code ,then it compiled successfully. and made the bin file
then download to the board for the printer
my printer can not connect computer with the firmware
Anyone could provide a correct code project , 078 or 1.09 ,please!
Re: ormerod firmware 078c
August 17, 2016 05:13AM
connecting....
can not initialize the sd card : card is unusable , try another one
RepRapFirmware version 1.09 dated 2015-04-21
Can't open 0:/sys/config.g to read , error code 12
Executing default.g (no configuration file found)...
Can't open 0:/sys/default.g to read , error code 12
Macro file dafault.g not found
T: B:67.3
T: B:67.3
T: B:67.3
T: B:67.3
----THIS is the massge of the connect above
August 17, 2016 05:27AM
either you have a bad SD card or an Empty Card. Try following this guide: [reprappro.com]
or [reprappro.com] for ormerod 1
Edited 1 time(s). Last edit at 08/17/2016 05:28AM by Darathy.
August 17, 2016 05:41AM
Hi Darathy
I'm sure my SD card is ok ,and not empty drinking smiley
there is four folder in SD card, as : gcodes macros sys www
August 17, 2016 05:46AM
Darathy
My printer was worked well before i change the firmware
I jast want to try compiled the code by myself, but got the problemsmiling smiley
August 17, 2016 08:11AM
I suggest you download and install a precompiled binary again and see if it can read your SD card. If so then there is probably something wrong with your compilation process.
Bear in minds that the RepRapPro release of RRF is no longer supported and hasn't been updated since April 2015. Most people use my fork or Chrishamm's fork these days.
August 17, 2016 11:42PM
dc42
when i downlode the last bin file firmware ,the printer is work well
i download the code from here
is the project your fork or Chrishamm's fork ?
which board should i choose?
should I used the hardware from the project i download ?
August 18, 2016 05:16AM
ormerod2004
i download the code from here [github.com]
That's old RRP release.
My fork: [github.com]
Chrishamm's fork: [github.com]
You may have to make some changes to other parts of the system when using more recent firmware, specifically:
1. Upgrade the /www files on the SD card to the compatible version of DuetWebControl (1.11 for my fork)
2. Add a M574 line to config.g to tell the firmware where your homing switches are (necessary for an Ormerod 1, optional for an Ormerod 2)
3. Make sure the X motor connector is the same way round as all the other connectors, or the X axis may move backwards.
4. If connecting to a Windows host computer via USB, install the device driver files at [github.com].
You may also wish to update the homeall.g file to do simultaneous X and Y homing.
Pleas explain what you mean.
August 18, 2016 06:00AM
dc42
ormerod2004
Very Thankful
I solved my problem,
i fand that the code for 1.09 should used the usb code from "Arduino Due (Native USB Port)"
so i instead of the usb code for the RepRap Duet Platform
Now,the printer could work.
I 'll try your fork and Chrishamm's fork
The last ,thanks for you help.
Could i ask your questions when i have a try? It seems ok for the answer,Right?hot smiley
