Issue with hobbed insert/extruder drive/hot end/filament blockage March 05, 2017 05:54PM |
Re: Issue with hobbed insert/extruder drive/hot end/filament blockage March 06, 2017 03:08AM |
Re: Issue with hobbed insert/extruder drive/hot end/filament blockage March 06, 2017 07:04AM |
Re: Issue with hobbed insert/extruder drive/hot end/filament blockage March 07, 2017 05:40AM |
dmould
[edit] - If you are getting small cracking sounds as the filament feeds, it may indicate that the filament has worn its way through the extruder entrance. Look underneath the curved part of the extruder where the filament enters - you may see a crack where the filament has worn through. If so, print another extruder housing before it fails completely. There is a modified design that has a bigger feed channel to take a PTFE liner (3mm OD, 2mm ID). I've recently had to do the same as the filament wore through both the PTFE liner and the printed part.
Dave
dmould
Dave
Re: Issue with hobbed insert/extruder drive/hot end/filament blockage March 07, 2017 07:02AM |
Re: Issue with hobbed insert/extruder drive/hot end/filament blockage March 07, 2017 08:41AM |
Re: Issue with hobbed insert/extruder drive/hot end/filament blockage March 07, 2017 01:04PM |
Re: Issue with hobbed insert/extruder drive/hot end/filament blockage March 07, 2017 03:57PM |
Sardi
- Screw holes are for a 2mm screw instead of a 3mm.
Sardi
EDIT: the 9mm bearing cant fit, all the holes are simply too narrow
Re: Issue with hobbed insert/extruder drive/hot end/filament blockage March 08, 2017 03:28AM |
ormerod168
btw, printing outer perimeters first could help
Erik
Re: Issue with hobbed insert/extruder drive/hot end/filament blockage March 08, 2017 07:05AM |
Re: Issue with hobbed insert/extruder drive/hot end/filament blockage March 08, 2017 07:19AM |
;Sliced at: {day} {date} {time} ;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density} ;Print time: {print_time} ;Filament used: {filament_amount}m {filament_weight}g ;Filament cost: {filament_cost} G21 ;metric values G90 ;absolute positioning M83 ; use relative distances for extrusion M203 X6000 Y6000 Z500 E3000 ; will allow 100mm/s sliced gcodes to work... if they have time/distance to get up to speed M116; Wait for all temperatures
Re: Issue with hobbed insert/extruder drive/hot end/filament blockage March 08, 2017 09:33AM |
Sardi
The print came out perfectly. Ptfe tube went in 40mm as it should, bearings fit nicely... I am a happy guy now..
Sardi
So as long as you are here, let me ask you just this, is this a good slic3r and cura start gcode?
Re: Issue with hobbed insert/extruder drive/hot end/filament blockage March 08, 2017 10:10AM |
Re: Issue with hobbed insert/extruder drive/hot end/filament blockage March 08, 2017 10:13AM |
Re: Issue with hobbed insert/extruder drive/hot end/filament blockage March 08, 2017 10:57AM |
Sardi
Let me pick your brain a bit more than, is S3D worth it?
Re: Issue with hobbed insert/extruder drive/hot end/filament blockage March 08, 2017 04:49PM |
Re: Issue with hobbed insert/extruder drive/hot end/filament blockage March 09, 2017 08:23AM |
Re: Issue with hobbed insert/extruder drive/hot end/filament blockage March 09, 2017 10:01AM |
dmould
considering it is pretty expensive software.
Re: Issue with hobbed insert/extruder drive/hot end/filament blockage March 09, 2017 10:40AM |
Re: Issue with hobbed insert/extruder drive/hot end/filament blockage March 10, 2017 06:56AM |
ormerod168
dmould
..The published STL for the Ormerod Z end cap..
Dave
Do you mean z-upper-mount - and published where?
Erik
Re: Issue with hobbed insert/extruder drive/hot end/filament blockage March 10, 2017 07:13AM |
Sardi
dmould
Exactly the reason Im asking
Thanks guys, Ill stick to Slic3r and Cura. In my experience, if an stl does not turn out good with one, it (almost always) will with the other one. The biggest difference I noticed are thin walls, while Cura has no problems with them, Slic3r tends not to do them very well.
Re: Issue with hobbed insert/extruder drive/hot end/filament blockage March 10, 2017 02:37PM |
dmould
Yes, the Z upper mount, published in the official RepRap "Ormerod-master/stl/individual parts" directory of the online repository that I picked up ages ago when I first got my Ormerod. I've attached it here. S3D places about 3 solid membranes at various heights inside the rectangular hollow box section (which it does not show on its 3D view, they appear after slicing).
Dave
Re: Issue with hobbed insert/extruder drive/hot end/filament blockage March 14, 2017 10:17AM |
ormerod168
Very strange, I don't see this and print just fine for me
Erik
Re: Issue with hobbed insert/extruder drive/hot end/filament blockage May 05, 2017 03:10PM |
