PanelDue is now better and cheaper! October 31, 2017 07:42AM |
Re: PanelDue is now better and cheaper! February 28, 2018 07:36PM |
Re: PanelDue is now better and cheaper! March 01, 2018 03:31AM |
Re: PanelDue is now better and cheaper! March 01, 2018 09:39AM |
Re: PanelDue is now better and cheaper! March 01, 2018 11:39PM |
Re: PanelDue is now better and cheaper! March 10, 2018 01:53AM |
dc42
First of all, don't try to power the PanelDue from the external 5V board, because that board can't power it without overheating. Use either the 5V regulator on the Duet, or power the PanelDue from a USB power supply and disconnect one end of the +5V wire in the cable. See the PanelDue fitting instructions.
The latest stable firmware for the Duet 0.6 is version 1.20 available at [github.com]. There are a number of things you may need to change in your config.g file when you upgrade, including:
- add commands to tell the firmware what endstops you have. For the Ormerod 2 I think these are M574 X1 S2 and M574 Y1 S1.
- the X axis may move in the wrong direction. Correct it using a M569 command.
There are probably other changes needed that I have forgotten. Test the IR sensor before you rely on it for homing.
