Smoke from heated bed
January 22, 2018 02:45PM
Hi all,
A bit worrying- I turned the printer bed to 57 degrees, and smoke gently started curling from the left hand side power connection of the heated bed.
Now there are black bits, and the solder is hot enough to flow if I poke it with tweezers.
LED was still on.
Underneath, the solder connector to the nut has gone very brown and burnt the tips of my fingers.
Not good. Luckily I was around and noticed quickly
I could buy a new heated bed, but is the bed likely to be the source of the problem? Or is there something else I should look at?
Ormerod 2, standard heated bed, Duet 0.6.
Many thanks.
Still slightly shocked..
Edited 1 time(s). Last edit at 01/22/2018 02:51PM by gwild.
Re: Smoke from heated bed
January 22, 2018 05:07PM
Early Ormerod 2s had a problem with the bed heater because they used screws to transfer the power from one side to the other, which wasn't satisfactory. Later ones used spade terminals soldered to the bed. If yours has 2 screws for the power connections instead of looking like the one pictured in the "528.4 onwards" tab at [reprappro.com], you have the old version.
Edited 1 time(s). Last edit at 01/22/2018 05:08PM by dc42.
January 22, 2018 05:51PM
Hi dc42,
You're right, I have the old style heated bed. Presumably the screws don't have enough surface area to transfer sufficient power?
Can you suggest where I might obtain the newer version of the heated bed for the Ormerod 2? [reprapltd.com] doesn't seem to carry them.
thanks!
January 23, 2018 05:47PM
I had the same problem with the same type of bed as yours. Instead of replacing the bed I soldered the power cables directly to the pads on top passing the cables up through the screw holes. Have been using it like this for a few years with no problems. Only disadvantage is that I cant disconnect the power cables from the bed, this isnt such a big problem as I can just disconnect from the duet end if I need to remove it.
January 24, 2018 10:14AM
Is there any way to replace the Ormerod 1 heatbed (with ribbon cable) with the Ormerod 2 heatbed (with all its cables)?
I have been using the Ormerod for 3 years now, but was never a fan of that ribbon cable and thin thermistor wires ...
January 24, 2018 03:20PM
The ribbon cable is very reliable, so I don't see any reason to replace it as long as you are using a Duet 0.6
I replaced the Duet 0.6 in my Ormerod by a Duet 0.8.5 recently. The 0.8.5 doesn't have the ribbon cable connector, so I had to replace the bed heater wires. I used thick highly-flexible loudspeaker wire for them. I kept 2 of the ribbon cables conductors for the thermistor.
January 25, 2018 07:14AM
dc42
I highly agree, never did fail on my two Ormerods
Erik
January 29, 2018 05:37PM
Thanks all. After I recovered from my slight shock, I soldered on the wires and all seems ok for now.
I'm very glad that the heated bed wasn't damaged, nor did my house burn down!
January 30, 2018 04:36AM
ormerod168
dc42
eh, I had a break in the ribbon thermistor cable, so had to connect the thermistor to the 2 pins located on the side of the ribbon cable pins.
