Wifi/ethernet conflict
November 16, 2018 04:30AM
Hi all,
I have a very annoying communications issue with a computer connected to an Ormerod 2 at work. Basically, it's either internet via wifi, or talking to the printer via ethernet, but not both at the same time.
The printer is attached to a Windows 7 computer via ethernet cable and so long as I don't plug in the Wifi dongle, I can talk to the printer without issue. When I plug in the Wifi dongle, I get internet connectivity but lose the ability to connect to the printer (browser reports request timed out). HOWEVER: I am still able to ping the printer! The Wifi adapter is configured for DHCP and the ethernet adapter as static IP. Sounds like a routing issue of some sort but I don't know enough about networking to fix it. Does anyone have any ideas?
I had the exact same problem on a previous computer that was connected to the printer but solved it by wiping everything and reinstalling Windows from scratch. This is quite a drastic measure and I'd rather not have to do it with this computer, especially after having spent hours/days downloading and installing updates (the computer had not been used for quite some time) and syncing Dropbox/Google drive/OneDrive!
Cheers,
Bart
Re: Wifi/ethernet conflict
November 16, 2018 05:45AM
With the wifi connected, press windows key and X key at the same time. Then click at Command Prompt. Type ipconfig /all at the Command Prompt window, press Enter,
Then do the same with the ethernet connected.
Paste the contents here, labelled (and preferably using the "formatted code" button in the post to make it more readable)
e.g.
Ethernet adapter Ethernet:
   Connection-specific DNS Suffix  . : cheeseandham.local
   Description . . . . . . . . . . . : Hyper-V Virtual Ethernet Adapter
   Physical Address. . . . . . . . . : 64-00-6A-98-85-B8
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   Link-local IPv6 Address . . . . . : fe80::4a5:79e4:6146:ee00%11(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.0.26(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : 14 November 2018 20:38:06
   Lease Expires . . . . . . . . . . : 17 November 2018 08:38:06
   Default Gateway . . . . . . . . . : 192.168.0.1
   DHCP Server . . . . . . . . . . . : 192.168.0.2
   DHCPv6 IAID . . . . . . . . . . . : 224657514
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1E-9E-CB-6C-64-00-6A-98-85-B8
   DNS Servers . . . . . . . . . . . : 8.8.8.8
                                       8.8.4.4
   Primary WINS Server . . . . . . . : 192.168.0.2
   NetBIOS over Tcpip. . . . . . . . : Enabled
And we'll see what we can see.
November 16, 2018 06:41AM
Hi cheeseandham,
Thanks for your reply.
The printer is configured for static IP, 192.168.0.20, gateway 192.168.0.1, netmask 255.255.255.0.
This is the output from ipconfig without the Wifi dongle attached:
Windows IP Configuration
   Host Name . . . . . . . . . . . . : BART-LAB-PC
   Primary Dns Suffix  . . . . . . . : campus.gla.ac.uk
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
   DNS Suffix Search List. . . . . . : campus.gla.ac.uk
Ethernet adapter Local Area Connection:
   Description . . . . . . . . . . . : Intel(R) 82579LM Gigabit Network Connection
   Physical Address. . . . . . . . . : F8-B1-56-D4-B0-14
   DHCP Enabled. . . . . . . . . . . : No
   Link-local IPv6 Address . . . . . : fe80::158e:8975:f3c:f63f%11(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.0.10(Preferred)
   DHCPv6 IAID . . . . . . . . . . . : 267956566
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1A-D9-88-78-F8-B1-56-D4-B0-14
                                       4.4.4.4
Tunnel adapter isatap.{70B4C8B4-2385-4A53-B4DE-F2E39913E697}:
   Media State . . . . . . . . . . . : Media disconnected
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter
   Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel adapter 6TO4 Adapter:
   Description . . . . . . . . . . . : Microsoft 6to4 Adapter
Tunnel adapter Local Area Connection* 11:
   Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
And this is the output with the Wifi dongle attached:
                                       gla.ac.uk
Wireless LAN adapter Wireless Network Connection:
   Connection-specific DNS Suffix  . : gla.ac.uk
   Description . . . . . . . . . . . : NETGEAR WNA3100M N300 Wireless Mini USB Adapter
   Physical Address. . . . . . . . . : 8C-3B-AD-D4-6A-9A
   Link-local IPv6 Address . . . . . : fe80::1175:1ab:df01:d3bd%14(Preferred)
   IPv4 Address. . . . . . . . . . . : 172.30.147.91(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.128.0
   Lease Obtained. . . . . . . . . . : 16 November 2018 11:31:58
   Lease Expires . . . . . . . . . . : 16 November 2018 11:46:57
   Default Gateway . . . . . . . . . : fe80::f2f7:55ff:febe:2680%14
                                       172.30.128.1
   DHCP Server . . . . . . . . . . . : 172.31.1.1
   DHCPv6 IAID . . . . . . . . . . . : 260848557
   DNS Servers . . . . . . . . . . . : 130.209.4.16
                                       130.209.4.18
                                       4.4.4.4
Tunnel adapter isatap.gla.ac.uk:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Cheers,
Bart
November 16, 2018 06:52AM
Bart,
It looks like you are configured for two different networks, and both are configured to go out to the Internet, but if the ethernet network isn't connected to the Internet then this could potentially cause a problem (although it is weird how you can still ping the printer)
Can you tell me more about the physical connectivity? How is it set up?
Is the physical network plugged into the Glasgow university campus, or is it just a physical network in your room?
If the physical network is not plugged into the wider network, then I would go to your static Ethernet settings and remove the Default gateway and the DNS servers so they are blank and see if that solves your issue.
If it is plugged into the uni network, then we'll wait until your reply with more information about the setup.
November 16, 2018 08:44AM
Hi cheeseandham,
Tried leaving the gateway and DNS fields blank: unfortunately that did not solve the problem.
The printer is connected directly to the computer's ethernet port with an ethernet cable. No intervening network. Internet connectivity is from the Wifi dongle.
Cheers,
Bart
November 16, 2018 10:56AM
Hey Bart,
That's odd. Anyway, default gateway is to tell that connection where to send packets that are not for that network. For the ethernet connection that should be blank. DNS has no point on that connection either, so leave blank for now so they do not have any effect.
From the command prompt can you paste the output from "route print" with both connections active. it should look like
Microsoft Windows [Version 10.0.17134.407]
(c) 2018 Microsoft Corporation. All rights reserved.
C:\Users\cheeseandham>route print
Interface List
 32...02 15 f7 e6 7d 39 ......Hyper-V Virtual Ethernet Adapter #2
  7...00 ff 2d 88 dc b3 ......TAP-NordVPN Windows Adapter V9
 26...64 00 6a 98 85 b8 ......Intel(R) Ethernet Connection (2) I219-V
 11...64 00 6a 98 85 b8 ......Hyper-V Virtual Ethernet Adapter
 13...18 4f 32 f2 11 78 ......Bluetooth Device (Personal Area Network) #2
  1...........................Software Loopback Interface 1
IPv4 Route Table
Active Routes:
Network Destination        Netmask          Gateway       Interface  Metric
          0.0.0.0          0.0.0.0      192.168.0.1     192.168.0.26     35
        127.0.0.0        255.0.0.0         On-link         127.0.0.1    331
        127.0.0.1  255.255.255.255         On-link         127.0.0.1    331
  127.255.255.255  255.255.255.255         On-link         127.0.0.1    331
      172.21.13.0  255.255.255.240         On-link       172.21.13.1    271
      172.21.13.1  255.255.255.255         On-link       172.21.13.1    271
     172.21.13.15  255.255.255.255         On-link       172.21.13.1    271
      192.168.0.0    255.255.255.0         On-link      192.168.0.26    291
     192.168.0.26  255.255.255.255         On-link      192.168.0.26    291
    192.168.0.255  255.255.255.255         On-link      192.168.0.26    291
        224.0.0.0        240.0.0.0         On-link         127.0.0.1    331
        224.0.0.0        240.0.0.0         On-link      192.168.0.26    291
        224.0.0.0        240.0.0.0         On-link       172.21.13.1    271
  255.255.255.255  255.255.255.255         On-link         127.0.0.1    331
  255.255.255.255  255.255.255.255         On-link      192.168.0.26    291
  255.255.255.255  255.255.255.255         On-link       172.21.13.1    271
Persistent Routes:
  None
IPv6 Route Table
Active Routes:
 If Metric Network Destination      Gateway
  1    331 ::1/128                  On-link
 11    291 fe80::/64                On-link
 26    291 fe80::/64                On-link
 32    271 fe80::/64                On-link
 11    291 fe80::4a5:79e4:6146:ee00/128
                                    On-link
 32    271 fe80::6c47:4533:8f75:307/128
                                    On-link
 26    291 fe80::d5ba:ff54:bb1d:72fb/128
                                    On-link
  1    331 ff00::/8                 On-link
 11    291 ff00::/8                 On-link
 26    291 ff00::/8                 On-link
 32    271 ff00::/8                 On-link
Persistent Routes:
  None
November 16, 2018 12:44PM
Hi cheeseandham,
The output of route print is:
Interface List
 14...8c 3b ad d4 6a 9a ......NETGEAR WNA3100M N300 Wireless Mini USB Adapter
 11...f8 b1 56 d4 b0 14 ......Intel(R) 82579LM Gigabit Network Connection
 15...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
 13...00 00 00 00 00 00 00 e0 Microsoft 6to4 Adapter
 12...00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
 16...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #2
IPv4 Route Table
Active Routes:
          0.0.0.0          0.0.0.0     172.30.128.1    172.30.166.79     25
        127.0.0.0        255.0.0.0         On-link         127.0.0.1    306
        127.0.0.1  255.255.255.255         On-link         127.0.0.1    306
  127.255.255.255  255.255.255.255         On-link         127.0.0.1    306
     172.30.128.0    255.255.128.0         On-link     172.30.166.79    281
    172.30.166.79  255.255.255.255         On-link     172.30.166.79    281
   172.30.255.255  255.255.255.255         On-link     172.30.166.79    281
      192.168.0.0    255.255.255.0         On-link      192.168.0.10    276
     192.168.0.10  255.255.255.255         On-link      192.168.0.10    276
    192.168.0.255  255.255.255.255         On-link      192.168.0.10    276
        224.0.0.0        240.0.0.0         On-link         127.0.0.1    306
        224.0.0.0        240.0.0.0         On-link      192.168.0.10    276
        224.0.0.0        240.0.0.0         On-link     172.30.166.79    281
  255.255.255.255  255.255.255.255         On-link         127.0.0.1    306
  255.255.255.255  255.255.255.255         On-link      192.168.0.10    276
  255.255.255.255  255.255.255.255         On-link     172.30.166.79    281
Persistent Routes:
  None
IPv6 Route Table
Active Routes:
 14     41 ::/0                     fe80::f2f7:55ff:febe:2680
  1    306 ::1/128                  On-link
 11    276 fe80::/64                On-link
 14    281 fe80::/64                On-link
 14    281 fe80::1175:1ab:df01:d3bd/128
                                    On-link
 11    276 fe80::158e:8975:f3c:f63f/128
                                    On-link
  1    306 ff00::/8                 On-link
 11    276 ff00::/8                 On-link
 14    281 ff00::/8                 On-link
Persistent Routes:
  None
Cheers,
Bart
November 18, 2018 08:31AM
Bart,
Looks normal enough, so there is something odd going on here. Obviously it's quite difficult to diagnose something like this remotely, especially as you are dealing with another network that is not under your control either.
Please do the following:-
i) let me know your printers IP address
ii) ping this address, with the Ethernet disconnected (yes I know, but just in case)
iii) try a/some different browser(s) to connect to the duet while the wifi is on.
iv) (i presume you've tried this) rebooting with both adapters on
Just something else to mention, I've used a TP-Link TL-WR802N in client mode.
Cheap and maybe a little slow compared to Ethernet, but worked perfectly well and would means that your printer would be wireless, and more importantly on the same network
November 18, 2018 01:19PM
This arrangement of ethernet cable to Ormerod and separate wifi from laptop to internet was how I first set up my Ormerod following the instructions on the RepRapPro site. The route involved bridging the networks in the laptop. The link [reprapltd.com] was described how to do it (although the URL to the page hasn't been resurrected from the archive) the host page [reprapltd.com] has and the non working link is under the "Connect via web interface section"
I jumped from XP to Windows 8 and now 10 but the way I remember to do it (in W10) is
Control panel/ All control panel items/Network connections Then right click the icon and select "Bridge connections". I can't remember which of the 2 networks to select but it must be worth experimenting.
Good luck
Dennis
November 21, 2018 01:35PM
Hi cheeseandham & Dennis,
Thanks for your suggestions, I tried them all but nothing seemed to help. For the record, the printer's address is 192.168.0.20 and I can't ping that address with the ethernet cable disconnected, booting with or without either adapter connected doesn't change a thing and neither does bridging the Wifi and LAN.
As I was getting quite annoyed by this, what with it being nearly 2019 and me thinking that I shouldn't have to choose between either internet or printer connectivity, I borrowed the Windows 7 install dongle from our IT guy and reinstalled the whole shebang. I now have both internet and can talk to the 3D printer! At the same time! Still got a million updates to download and install, all my other software, and I don't even want to think about syncing Dropbox, Google drive and Onedrive, but at least both networks are working!
Thanks for all your help!
Bart
Edited 2 time(s). Last edit at 11/21/2018 01:38PM by bartdietrich.
November 21, 2018 03:48PM
Bart,
This was a bizarre issue, as Windows should deal with that configuration in normal operation.
I wonder if this and the other machine that suffered from this are from the same manufacturer or even the same model line? Perhaps the company that created their standard image made a mistake somewhere.
Glad it is fixed!
