Re: BackEMF's SmartRap 0.4.7 build May 23, 2014 07:36PM |
Re: BackEMF's SmartRap 0.4.7 build May 23, 2014 07:52PM |
Re: BackEMF's SmartRap 0.4.7 build May 23, 2014 08:49PM |
Re: BackEMF's SmartRap 0.4.7 build May 23, 2014 09:04PM |
Re: BackEMF's SmartRap 0.4.7 build May 23, 2014 09:43PM |
Re: BackEMF's SmartRap 0.4.7 build May 24, 2014 05:15AM |
Re: BackEMF's SmartRap 0.4.7 build May 24, 2014 06:36AM |
Re: BackEMF's SmartRap 0.4.7 build June 06, 2014 01:04PM |
Re: BackEMF's SmartRap 0.4.7 build June 06, 2014 04:06PM |
Re: BackEMF's SmartRap 0.4.7 build June 06, 2014 08:11PM |
BackEMF
Today Reg's package arrived.
Thanks Reg, that hotend looks great!
So i will be doing some mods tomorrow. . :-D
Re: BackEMF's SmartRap 0.4.7 build June 08, 2014 11:47AM |
Re: BackEMF's SmartRap 0.4.7 build June 08, 2014 07:55PM |
BackEMF
Almost done, I ran out of crimp connectors.... So that's for tomorrow.
Regpye, what setting do you use for the thermistor?
And I still need to get the extruder steps right. The summer temperature is messing with my head, it's kinda hard for me to think with a sintered brain... :-)
Re: BackEMF's SmartRap 0.4.7 build June 09, 2014 04:50AM |
Re: BackEMF's SmartRap 0.4.7 build June 09, 2014 05:08AM |
BackEMF
ok Thx,
I hope my friend has a few crimp connectors, shops are closed since today is another sunday. ...the holy book is messing with progress.
Else i will work on the ATX idea.
Re: BackEMF's SmartRap 0.4.7 build June 09, 2014 05:34AM |
Re: BackEMF's SmartRap 0.4.7 build June 11, 2014 01:57PM |
Re: BackEMF's SmartRap 0.4.7 build June 18, 2014 08:30PM |
Re: BackEMF's SmartRap 0.4.7 build June 18, 2014 08:53PM |
BackEMF
Alright, i have some catching up to do.
The pas couple of days i've been printing in the little spare time i had.
Some feedback on Regpye's hotend:
I started with the .4 nozzle that all printed very nice, absolutely nothing wrong with that. So then i moved to test the .5 nozzle.
At first it printed great, then after some time due to leakage things got a bit messy. Reg already told me to tighten it when hot and so i did, several times. and finally the leakage seemed to stop. So i printed more, speeded up, adjusted the temperature, and the prints came out very nice (a few boring calibration prints).
Then i discovered that there was more leakage above the heaterblock the PLA is now flowing out. The printing is just fine as long as i clean up the drops, though Reg, you might want to look deeper into this issue.
I'm now printing with .5 nozzle, 30mm/sec (walls at 25mm/sec), temperature 203C Maybe the walls are a bit to fast, the corners are not as tight as with the .4 nozzle.
The calibration cube i'm printing is with 100% infil printed with naturel PLA
And with this translucent PLA nice to see how good the infill is fused together. BTW this seems to be usable as a lightpipe although it is a bit yellow-ish.
So far for the first bit of feedback on the hotend.
Re: BackEMF's SmartRap 0.4.7 build June 19, 2014 09:20PM |
Re: BackEMF's SmartRap 0.4.7 build June 19, 2014 09:22PM |
BackEMF
I send the PM before i've read this,
I'll have a look at it tomorrow and see if I can fix it. After seeing that drawing i think it is what i described in the PM, I think it could have dislocated then i changed the nozzle's
Re: BackEMF's SmartRap 0.4.7 build June 19, 2014 09:37PM |
Re: BackEMF's SmartRap 0.4.7 build June 23, 2014 08:15AM |
Re: BackEMF's SmartRap 0.4.7 build June 23, 2014 08:19AM |
BackEMF
Im having a fight with the slicers.
When i place the Rack and pineon part diagonal on the bed and slice it up then both slicer and cura manage to skew the layers, at first i tought it was slipping fishing line ore skipping steppers but it's really a slicing issue. when i turn the part 180 degrees then the skew moves along to the other side.... and when i print other long parts diagonal then they slice and print just fine.
What can be done about this?
Re: BackEMF's SmartRap 0.4.7 build June 23, 2014 09:06AM |
Re: BackEMF's SmartRap 0.4.7 build July 04, 2014 11:52AM |
Re: BackEMF's SmartRap 0.4.7 build July 04, 2014 07:17PM |
Re: BackEMF's SmartRap 0.4.7 build July 04, 2014 07:56PM |
Re: BackEMF's SmartRap 0.4.7 build July 05, 2014 09:16AM |
Re: BackEMF's SmartRap 0.4.7 build July 05, 2014 11:53AM |
MelT
2 turns just doesn't sound like it can grip the shaft well.
Make it 5 turns at least. I've never had a problem with this many turns. You might want to try that.
Re: BackEMF's SmartRap 0.4.7 build July 05, 2014 02:02PM |
