Re: Looking for some help some, tips June 08, 2014 01:10AM |
Re: Looking for some help some, tips June 08, 2014 01:12AM |
djinn5150
I tried Cura and got 1 good print out of it, I really like the simplicity of the interface but for some reason It seems I need to calibrate the z-offset almost every print, and since the 1st print with cura I cannot get it to actually lay anything down on the bed, its always just a smidge too high for some reason and nothing sticks. I'll figure it out someday. On another note I did get my little 16x2 LCD up and running today so there's that Always improving
Re: Looking for some help some, tips June 08, 2014 10:35AM |
Re: Looking for some help some, tips June 08, 2014 11:38AM |
Re: Looking for some help some, tips June 08, 2014 12:41PM |
Re: Looking for some help some, tips June 08, 2014 02:05PM |
Re: Looking for some help some, tips June 08, 2014 02:45PM |
regpye
What have you got in the Cura start code?
;Sliced at: {day} {date} {time} ;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density} ;Print time: {print_time} ;Filament used: {filament_amount}m {filament_weight}g ;Filament cost: {filament_cost} ;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line ;M109 S{print_temperature} ;Uncomment to add your own temperature line G21 ;metric values G90 ;absolute positioning M82 ;set extruder to absolute mode M107 ;start with the fan off G1 Z10.0 F[travel_speed}; G28 X0 Y0 Z0 ;move X/Y to min endstops G29 ;autolevel bed G92 E0 ;zero the extruded length G1 F200 E3 ;extrude 3mm of feed stock G92 E0 ;zero the extruded length again G1 F{travel_speed} ;Put printing message on LCD screen M117 Printing...
Re: Looking for some help some, tips June 08, 2014 02:57PM |
markstephen
That's looking better. Looks like the feed slowed a bit in spots, but is definitely an improvement.
Here are a couple of prints I did last night, Jack Blocks (step blocks) and Hold Downs for my CNC router. I was at the very limit for my text size on this one. Click the url just below the pic for high rez. Sliced with CuraEngine 14.3 and printed on my Smartrap using the J Head Light V2.
Mark
Ready for action
Almost able to read the small "mm" under the numbers.
Measuring the actual height of the 20 mm step.
Re: Looking for some help some, tips June 11, 2014 12:35PM |
Re: Looking for some help some, tips June 11, 2014 07:07PM |
djinn5150
I think my Ramps board or stepper drivers are going bad/gone bad something, or could be PSU. Its acting really weird now, sometimes an axis(happens on all) will not respond to command, or if it does...say I send x + 10 from pronterface x will move in + then I send again it moves in - At first I thought It was maybe firmware so I tried loading sprinter and almost same thing happens not sure where to look where to start. I also tried starting fresh with marlin and get similar results. Oddly the extruder works just fine. If I swap x y z around they all act in a similar fashion.
Anyone have any thoughts or run across a similar problem?
Thanks again
If it helps my Marlin can be found here
Re: Looking for some help some, tips June 12, 2014 06:52PM |
Re: Looking for some help some, tips June 19, 2014 05:50PM |
Re: Looking for some help some, tips June 19, 2014 07:23PM |
djinn5150
So how much failure should a noob expect? I am getting very frustrated with this, and while my ego will not let it beat me I am getting very frustrated and doubting everything at this point.
I just don't get how I can have a beautiful print one second then try something else and it just fails miserably. I know I am having extrusion/feed issues that I can't seem to wrap my head around, my PLA(from javascript:editor_tools_handle_help()JustPLA) seems to be pretty consistant at 1.75 +- .01. All my lines are very tight, almost to the point I felt like the ends were going to snap as I tighned things down. All the axis have a smooth movement to them. Its not as if the prints are out of shape or anything its mostly in extrusion slow downs, and at times the offset seems to be way off or the z position is. After a g29 probe it will warm up then start to print and be like .3mm above where it should be. I am thinking one of the "add-on" extruders from thingiverse or regpye's from the github files will help but I can't even get those to print of course.
Its not like I am totally inexperienced in computers, arduino's, electronics etc etc so its not like I can't comprehend this stuff. I know I cheaped out on some stuff could it be my electronics? Mostly my hotend, It is a china MK-V knockoff, precisely its this one.. Is there anything I can do improve on this thing?
I just don't know where to try and figure this out....but I feel like I am loosing my mind here.
Re: Looking for some help some, tips June 21, 2014 08:06PM |
Re: Looking for some help some, tips June 21, 2014 08:12PM |
djinn5150
Well looks like I got most of my issues settled out, at least for now. I have had several successful prints at this point and will be changing to a Wades extruder not to far into the future. But for now it seems to be working quite well. Once I get a few brackets printed I will get my "build" finalized and start a new thread with some photos.
Re: Looking for some help some, tips June 21, 2014 08:27PM |
Isn't that the truth, and honestly I think most of my problems were in my inexperience in setting up slicer and impatience, at least for my build 30mm/s is just to fast for decent prints, running at 20 and things are going well. I would love to pull a bit more speed out of if but I am not going to look a printed gift horse in the mouthQuote
regpye
Looking good now.
Pays to stay with it for a while, the problems are very good, it makes you learn something.
If you had just bought it ready to print out of the box you would not appreciate the machine as much.
Re: Looking for some help some, tips June 21, 2014 08:33PM |
djinn5150
regpye
Looking good now.
Re: Looking for some help some, tips June 21, 2014 08:49PM |
Re: Looking for some help some, tips June 21, 2014 09:37PM |
djinn5150
Awesome I will for sure have a look, maybe I'll just go that way instead of the this Wades I printed out, can't hurt to have extra parts laying around. I do like your's and its "add-on" style to the Smartrap, maybe I'll give it a go now things are running so smooth. Any tips on learning CAD on the side. I never have had any experience in it at all. I have been able to make a few things in sketch up but, trying to do some things in it is just leaving me lost. I am trying to make a set of mounting rings for a guidescope for my father and his telescope and just keep falling short with adding holes for the adjustment screws in the rings. Essentially trying to model something like this from scratch.
