Stabilizing X Axis on 0.4.7 and Earlier Designs July 30, 2014 12:34AM |
Re: Stabilizing X Axis on 0.4.7 and Earlier Designs July 30, 2014 12:39AM |
x86Daddy
I built my SmartRap using mostly a set of parts based on the 0.4.6 version. I may upgrade to newer parts over time. The main thing that bothered me was the amount of bending upward the X axis does during Z-homing, exacerbated by the fact that I'm using a servoless probe method. I figured out a quick 2-cent solution, literally, and figured I'd share. I haven't tested it much yet, but so far, I'm impressed with the improved rigidity. Hope this helps someone.
[attachment 37492 2cent.jpg]
Re: Stabilizing X Axis on 0.4.7 and Earlier Designs July 30, 2014 05:11AM |
Re: Stabilizing X Axis on 0.4.7 and Earlier Designs July 30, 2014 05:18AM |
BackEMF
You can also put some paper, or soft plastic between the LM8UU and the top clamp.
the 0.47 has 3mm holes on the sides there so that you can clamp it down by screwing M3 's in.
LOL @ Reg, it's cheaper to drill a hole in a coin then actually go to the hardware store to buy a washer.
