loidor
Right, my repstrap is close to finished, and I'm about to testprint later tonight.
Thing is, the build area came out a bit smaller than expected. X is 80 mm and Y is 55 mm, but I can probably stretch Y a bit (I guess I can get it up to 80 mm as well). Z is about 80 mm as well. What's the dimensions of the largest smartrap part?
My SmartRaps print on a build plate that measures 250 x 225 and the height is near 200mm high.
You don't have to follow the same build dimensions, you can change things to suit what you want.
Using a Genie hotend, you can also print at high quality and fast.
I also use a heated bed so that there are even more options available.
regpye.com.au]
"Experience is the mother of all knowledge." --Leonardo da Vinci
