Re: Sethmo's Smartrap Core Build v1.0 May 13, 2015 08:15AM |
I am a dummy, I did not realize that the hot end mount was separate from the entire block body lol. It should print fine without supports once I split them. I was however able to print both pieces together with supports and it turned out not completely terrible lol.Quote
smartfriendz
That's strange, it is designed to print stand up ? I've made angles under the belt tensioners so it could print like it is . If you remove support system it should print ok (we do actually pretty good here ) .
mandrav
sethmo
I ended up getting my chassis together last night. I am going to put a small brace across the top front to help close and square it up. I also for some reason made the whole thing too tall, so I need to cut about an 1-1/2" off the top, shouldn't be too bad.I was thinking about adding about 6" to the whole thing and adding a floor so I would have an enclosed space for the electronics, but I decided to keep it simple.
Lol, you 're describing my box
I 've built it exactly like this back in December (or was it November?), when I was first aware of smartcore's existence:
A 100mm brace across the top front (which also doubles as a mount space for camera and/or spool holder) and a fake "floor" (another 100mm) at the bottom where all electronics (ramps+octoprint+powersupply) are mounted and wired through small (12mm) holes in the floor corners.
Re: Sethmo's Smartrap Core Build v1.0 May 13, 2015 03:54PM |
Re: Sethmo's Smartrap Core Build v1.0 May 14, 2015 01:43PM |
Re: Sethmo's Smartrap Core Build v1.0 May 19, 2015 09:46AM |
Re: Sethmo's Smartrap Core Build v1.0 May 19, 2015 10:29AM |
Re: Sethmo's Smartrap Core Build v1.0 May 19, 2015 11:05AM |
Re: Sethmo's Smartrap Core Build v1.0 May 19, 2015 12:55PM |
Re: Sethmo's Smartrap Core Build v1.0 May 19, 2015 02:33PM |
Haha I love my mallet! I have a hammer in my office with a "ASUS Repair Kit" label on itQuote
rcjoseb
SmartRapCore adjustment tool!! Comes in handy!
Re: Sethmo's Smartrap Core Build v1.0 May 19, 2015 04:53PM |
Re: Sethmo's Smartrap Core Build v1.0 May 19, 2015 05:03PM |
Re: Sethmo's Smartrap Core Build v1.0 May 20, 2015 07:10AM |
Re: Sethmo's Smartrap Core Build v1.0 May 20, 2015 02:39PM |
Re: Sethmo's Smartrap Core Build v1.0 May 20, 2015 03:42PM |
I used this is the enclosureQuote
Zlob
I love your LCD enclosure .. can we have the stl file ?
And what is "3 in1 oil" ???
thanks
Re: Sethmo's Smartrap Core Build v1.0 May 20, 2015 03:51PM |
Re: Sethmo's Smartrap Core Build v1.0 May 20, 2015 05:01PM |
Re: Sethmo's Smartrap Core Build v1.0 May 20, 2015 07:02PM |
Zlob
Thanks a lot for the enclosure links.
The oil will remain an enigma ...
I never ssee something like that in italy ...
I must investigate for it !
Thanks again !!!
Re: Sethmo's Smartrap Core Build v1.0 May 21, 2015 04:26AM |
Re: Sethmo's Smartrap Core Build v1.0 May 21, 2015 04:29AM |
Re: Sethmo's Smartrap Core Build v1.0 May 21, 2015 10:00AM |
Re: Sethmo's Smartrap Core Build v1.0 May 21, 2015 11:56AM |
Re: Sethmo's Smartrap Core Build v1.0 May 21, 2015 01:58PM |
Re: Sethmo's Smartrap Core Build v1.0 May 21, 2015 02:32PM |
Re: Sethmo's Smartrap Core Build v1.0 May 22, 2015 05:36AM |
Re: Sethmo's Smartrap Core Build v1.0 May 22, 2015 07:25AM |
Re: Sethmo's Smartrap Core Build v1.0 May 22, 2015 09:28AM |
mandrav
Here's the modified head.stl for LM8UU, if anyone needs it.
I printed it yesterday and it's running as expected so, yeah, it's also tested
Re: Sethmo's Smartrap Core Build v1.0 May 22, 2015 11:38AM |
Re: Sethmo's Smartrap Core Build v1.0 May 25, 2015 11:11AM |
Re: Sethmo's Smartrap Core Build v1.0 May 25, 2015 12:20PM |
Re: Sethmo's Smartrap Core Build v1.0 May 26, 2015 11:58AM |
Re: Sethmo's Smartrap Core Build v1.0 May 26, 2015 12:31PM |
