Re: Another Smart Rap Core build June 04, 2015 09:40AM |
Re: Another Smart Rap Core build June 04, 2015 11:51AM |
Re: Another Smart Rap Core build June 04, 2015 11:57AM |
Re: Another Smart Rap Core build June 04, 2015 12:49PM |
Re: Another Smart Rap Core build June 04, 2015 01:36PM |
); Not sure 100% for the pulley, i had to ask.|
Re: Another Smart Rap Core build June 04, 2015 02:40PM |
Re: Another Smart Rap Core build June 06, 2015 02:47AM |
Re: Another Smart Rap Core build June 07, 2015 05:36PM |
Re: Another Smart Rap Core build June 08, 2015 12:11PM |
Re: Another Smart Rap Core build June 08, 2015 04:08PM |
//Travel limits after homing (units are in mm) #define X_MIN_POS 0 #define Y_MIN_POS 0 #define Z_MIN_POS 0 #define X_MAX_POS 200 #define Y_MAX_POS 200 #define Z_MAX_POS 180
//If you have enabled the Bed Auto Leveling and are using the same Z Probe for Z Homing,
//it is highly recommended you let this Z_SAFE_HOMING enabled!!!
#define Z_SAFE_HOMING // This feature is meant to avoid Z homing with probe outside the bed area.
// When defined, it will:
// - Allow Z homing only after X and Y homing AND stepper drivers still enabled
// - If stepper drivers timeout, it will need X and Y homing again before Z homing
// - Position the probe in a defined XY point before Z Homing when homing all axis (G28)
// - Block Z homing only when the probe is outside bed area.
#ifdef Z_SAFE_HOMING
#define Z_SAFE_HOMING_X_POINT (X_MAX_LENGTH/2) // X point for Z homing when homing all axis (G28)
#define Z_SAFE_HOMING_Y_POINT (Y_MAX_LENGTH/2) // Y point for Z homing when homing all axis (G28)
#endif
Re: Another Smart Rap Core build June 11, 2015 12:58PM |
Re: Another Smart Rap Core build June 15, 2015 06:29AM |
Re: Another Smart Rap Core build June 15, 2015 07:39AM |
Re: Another Smart Rap Core build June 15, 2015 10:45AM |
Re: Another Smart Rap Core build June 15, 2015 10:54AM |
Re: Another Smart Rap Core build June 15, 2015 12:47PM |
Re: Another Smart Rap Core build June 15, 2015 01:20PM |
Re: Another Smart Rap Core build June 15, 2015 04:41PM |
Re: Another Smart Rap Core build June 15, 2015 06:45PM |
Re: Another Smart Rap Core build June 16, 2015 04:57AM |
!) the value directly from the chip.|
Re: Another Smart Rap Core build June 16, 2015 07:05AM |
Re: Another Smart Rap Core build June 16, 2015 09:49AM |
Re: Another Smart Rap Core build June 16, 2015 05:56PM |
Re: Another Smart Rap Core build June 17, 2015 04:30AM |
smartfriendz
that's strange with the build volume ? Normally, if you enter 250x250x250 in the print size, you will go for 315 mm X rod size, for example and that should give you around 250mm printable on X ( with a 250 wide plate of course ).
I will check again though..
Re: Another Smart Rap Core build June 17, 2015 08:40AM |
Re: Another Smart Rap Core build June 17, 2015 10:05AM |
Re: Another Smart Rap Core build June 17, 2015 10:12AM |
Re: Another Smart Rap Core build June 17, 2015 10:47AM |
Re: Another Smart Rap Core build June 17, 2015 04:38PM |
mandrav
I mean, once you *manually* level your bed once, there is really no reason for it to become non-level. Why have an auto-leveling process which tries to correct your non-level bed when you could just level it once and be done with it? Also, with auto-leveling enabled, your Z motor(s) will be constantly working throughout the print adding even more variables to the final print quality (e.g. backlash, microsteps accuracy, etc).
It's like having slightly punctured tires on your car, losing air pressure daily, and instead of getting them fixed (or changed), you prefer to have to inflate them each morning before you begin your day...
Re: Another Smart Rap Core build June 26, 2015 04:02PM |
