Another newbie's Smarcore build July 17, 2015 02:03PM |
Re: Another newbie's Smarcore build July 26, 2015 02:38PM |
Re: Another newbie's Smarcore build July 30, 2015 10:54AM |
Re: Another newbie's Smarcore build July 31, 2015 07:42AM |
Re: Another newbie's Smarcore build July 31, 2015 02:54PM |
Re: Another newbie's Smarcore build July 31, 2015 05:50PM |
Re: Another newbie's Smarcore build July 31, 2015 05:58PM |
Re: Another newbie's Smarcore build August 01, 2015 11:20AM |
Re: Another newbie's Smarcore build August 05, 2015 10:48AM |
Re: Another newbie's Smarcore build August 05, 2015 03:57PM |
Re: Another newbie's Smarcore build August 05, 2015 05:33PM |
Re: Another newbie's Smarcore build August 06, 2015 03:52PM |
Re: Another newbie's Smarcore build August 22, 2015 03:15PM |
Re: Another newbie's Smarcore build August 23, 2015 09:03AM |
MichaelBrock
I finally have the printed pieces in hand and I'm starting assembly. These are versin 1.2.4 pieces. However, i'm having an issue with the xy head assembly. The bearings are sliding very well on the smooth rod when not in the mount but when put into the head assembly they are slightly out of alignment and grab. For the bottom pair of bearings I managed to loosen up the mount enough (by prying open the "clamp" a bit") that the two bearings are able to align themselves and now they move well. However, this approach isn't an option with the top pair. My plan now is to use a dremel to carve out the bearing mount area a bit so that the two bearings are able to align themselves. Of course, not having the option of being able to print a replacement, I'm a bit hesitant.
Any suggestions, perhaps a better way to loosen things up, before I jump in and start making modifications?
Re: Another newbie's Smarcore build September 09, 2015 01:28PM |
Re: Another newbie's Smarcore build September 20, 2015 04:46PM |
Re: Another newbie's Smarcore build September 20, 2015 05:09PM |
Re: Another newbie's Smarcore build September 20, 2015 05:26PM |
Re: Another newbie's Smarcore build September 20, 2015 05:56PM |
Re: Another newbie's Smarcore build September 20, 2015 07:56PM |
Re: Another newbie's Smarcore build September 20, 2015 08:11PM |
Re: Another newbie's Smarcore build September 21, 2015 12:03AM |
Re: Another newbie's Smarcore build September 21, 2015 12:22AM |
Re: Another newbie's Smarcore build September 21, 2015 04:34AM |
Re: Another newbie's Smarcore build September 21, 2015 09:19AM |
mandrav
Also, check the value of Z_MAX_POS in configuration.h and raise it if it's lower than your real Z travel.
I haven't seen this with marlin before (I 've seen it though with grbl), but I always had this defined to be larger than my real Z travel.
The reasoning is that, while trying to reach home (during homing), it travels more than (Z_MAX_POS - Z_MIN_POS) and it stops because it thinks it's gone out of bounds...
Heh, it's a shot in the dark but you don't lose anything to try it
Re: Another newbie's Smarcore build September 21, 2015 09:59AM |
Re: Another newbie's Smarcore build September 25, 2015 08:24AM |
Re: Another newbie's Smarcore build September 25, 2015 01:05PM |
Re: Another newbie's Smarcore build September 25, 2015 01:39PM |
Zlob
Hi, I use a cheap "aliexpress" e3d clone too.
Look like u are using a too low PLA temp. I usually use 200° or 205° without heated bed, and 195° with heated bed.
Also, check that the temp. sensor is in good contect with metal. If not use alu foil (cooking one!) to made good contact.
Hope it help.
Re: Another newbie's Smarcore build September 26, 2015 01:32PM |
