ReplikatorG July 08, 2010 12:35PM |
tool name="Mendel Stepper Extruder" type="extruder" material="abs" motor="true" floodcoolant="false" mistcoolant="false" fan="true" valve="false" collet="false" heatedplatform="true" heater="true" motor_steps="200"
Aller Anfang war schwer - Wolfstrap | Reprap-fab.org |
Re: ReplikatorG July 08, 2010 04:00PM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: ReplikatorG July 08, 2010 07:03PM |
Re: ReplikatorG July 08, 2010 09:29PM |
Re: ReplikatorG July 09, 2010 03:32AM |
Die konvertieren die Firmware irgendwie in diese Hex-Files... aber ich weis nicht wie.
Re: ReplikatorG July 09, 2010 04:39AM |
Admin Registered: 16 years ago Posts: 13,891 |
Re: ReplikatorG July 09, 2010 05:41AM |
Re: ReplikatorG July 09, 2010 06:01AM |
Re: ReplikatorG July 09, 2010 06:14AM |
Re: ReplikatorG July 09, 2010 06:24AM |
o: In function `loop': C:\DOKUME~1\HP_ADM~1\LOKALE~1\Temp\build174863406251042990.tmp/ArduinoSlaveExtruder.cpp:89: undefined reference to `process_packets()' C:\DOKUME~1\HP_ADM~1\LOKALE~1\Temp\build174863406251042990.tmp/ArduinoSlaveExtruder.cpp:92: undefined reference to `motor1_reversal_state' C:\DOKUME~1\HP_ADM~1\LOKALE~1\Temp\build174863406251042990.tmp/ArduinoSlaveExtruder.cpp:93: undefined reference to `reverse_motor_1()' C:\DOKUME~1\HP_ADM~1\LOKALE~1\Temp\build174863406251042990.tmp/ArduinoSlaveExtruder.cpp:96: undefined reference to `is_tool_paused' C:\DOKUME~1\HP_ADM~1\LOKALE~1\Temp\build174863406251042990.tmp/ArduinoSlaveExtruder.cpp:98: undefined reference to `extruder_heater' C:\DOKUME~1\HP_ADM~1\LOKALE~1\Temp\build174863406251042990.tmp/ArduinoSlaveExtruder.cpp:98: undefined reference to `extruder_heater' C:\DOKUME~1\HP_ADM~1\LOKALE~1\Temp\build174863406251042990.tmp/ArduinoSlaveExtruder.cpp:98: undefined reference to `Heater::manage_temperature()' C:\DOKUME~1\HP_ADM~1\LOKALE~1\Temp\build174863406251042990.tmp/ArduinoSlaveExtruder.cpp:101: undefined reference to `platform_heater' C:\DOKUME~1\HP_ADM~1\LOKALE~1\Temp\build174863406251042990.tmp/ArduinoSlaveExtruder.cpp:101: undefined reference to `platform_heater' C:\DOKUME~1\HP_ADM~1\LOKALE~1\Temp\build174863406251042990.tmp/ArduinoSlaveExtruder.cpp:101: undefined reference to `Heater::manage_temperature()' o: In function `initialize()': C:\DOKUME~1\HP_ADM~1\LOKALE~1\Temp\build174863406251042990.tmp/ArduinoSlaveExtruder.cpp:70: undefined reference to `is_tool_paused' C:\DOKUME~1\HP_ADM~1\LOKALE~1\Temp\build174863406251042990.tmp/ArduinoSlaveExtruder.cpp:71: undefined reference to `initThermTable()' C:\DOKUME~1\HP_ADM~1\LOKALE~1\Temp\build174863406251042990.tmp/ArduinoSlaveExtruder.cpp:72: undefined reference to `init_extruder()'
Re: ReplikatorG July 09, 2010 06:29AM |
Re: ReplikatorG July 09, 2010 06:46AM |
Re: ReplikatorG July 09, 2010 07:08AM |
Re: ReplikatorG July 09, 2010 07:18AM |
Re: ReplikatorG July 09, 2010 10:57AM |
c:\Programme\arduino-0018\examples\v2>scons scons: Reading SConscript files ... scons: warning: No installed VCs File "C:\Programme\arduino-0018\examples\v2\SConstruct", line 1, in scons: warning: No version of Visual Studio compiler found - C/C++ compilers mos t likely not set correctly File "C:\Programme\arduino-0018\examples\v2\SConstruct", line 1, in IndexError: list index out of range: File "C:\Programme\arduino-0018\examples\v2\SConstruct", line 1: SConscript(['src/Motherboard/SConscript'], variant_dir='build') File "c:\Python26\Lib\site-packages\scons-2.0.0.final.0\SCons\Script\SConscrip t.py", line 614: return method(*args, **kw) File "c:\Python26\Lib\site-packages\scons-2.0.0.final.0\SCons\Script\SConscrip t.py", line 551: return _SConscript(self.fs, *files, **subst_kw) File "c:\Python26\Lib\site-packages\scons-2.0.0.final.0\SCons\Script\SConscrip t.py", line 260: exec _file_ in call_stack[-1].globals File "C:\Programme\arduino-0018\examples\v2\build\SConscript", line 95: avr_tools_path = dirname(os.popen('/usr/bin/which avr-gcc').readlines()[0]) c:\Programme\arduino-0018\examples\v2>
Re: ReplikatorG July 09, 2010 12:52PM |
if (os.environ.has_key('AVR_TOOLS_PATH')): avr_tools_path = os.environ['AVR_TOOLS_PATH'] else: avr_tools_path = dirname(os.popen('/usr/bin/which avr-gcc').readlines()[0])
Re: ReplikatorG July 10, 2010 04:10AM |
Re: ReplikatorG July 10, 2010 06:25AM |
Re: ReplikatorG July 11, 2010 03:06PM |
Re: ReplikatorG July 11, 2010 06:32PM |
Re: ReplikatorG July 12, 2010 02:08PM |
Re: ReplikatorG July 12, 2010 03:56PM |
Re: ReplikatorG July 12, 2010 04:00PM |
Re: ReplikatorG July 12, 2010 04:16PM |
Re: ReplikatorG July 12, 2010 04:28PM |
Re: ReplikatorG July 12, 2010 04:30PM |
Re: ReplikatorG July 12, 2010 04:58PM |
Re: ReplikatorG July 12, 2010 08:54PM |
Re: ReplikatorG July 13, 2010 05:06AM |
/* * Copyright 2010 by Adam Mayer * * This program is free software: you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by * the Free Software Foundation, either version 3 of the License, or * (at your option) any later version. * * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. * * You should have received a copy of the GNU General Public License * along with this program. If not, see [www.gnu.org] */ #ifndef BOARDS_ECV22_CONFIGURATION_HH_ #define BOARDS_ECV22_CONFIGURATION_HH_ // Board configuration files define pin configurations // for different motherboards, as well as available // features. #include "AvrPort.hh" #define DEVICE_ID 0 // Interval for timer update in microseconds #define INTERVAL_IN_MICROSECONDS 64 // Power supply control pin #define HAS_PSU 0 // SD card pins #define HAS_SD 0 // Host RS485 UART configuration #define HAS_SLAVE_UART 0 #define TX_ENABLE_PIN Pin(PortC,2) #define RX_ENABLE_PIN Pin(PortD,4) // Extrusion head heater configuration #define HAS_HEATER 1 #define HAS_THERMISTOR 1 // Extruder thermistor analog pin #define THERMISTOR_PIN 3 // Heated platform configuration #define HAS_HEATED_PLATFORM 0 // Platform thermistor analog pin #define PLATFORM_PIN 6 // Fan configuration #define HAS_FAN 1 #define FAN_ENABLE_PIN Pin(PortB,4) #define HAS_DC_MOTOR 1 #define MOTOR_ENABLE_PIN Pin(PortD,5) #define MOTOR_DIR_PIN Pin(PortD,7) #define DEBUG_LED Pin(PortB,5) #define SAMPLE_INTERVAL_MICROS_THERMISTOR (50L * 1000L) #endif // BOARDS_ECV22_CONFIGURATION_HH_
Re: ReplikatorG July 13, 2010 06:07AM |
(beim Stepper sind es ja 4)
