problemi di configurazione E1 July 23, 2014 07:38AM |
Re: problemi di configurazione E1 July 23, 2014 08:43AM |
Re: problemi di configurazione E1 July 23, 2014 09:30AM |
Re: problemi di configurazione E1 July 23, 2014 12:31PM |
Re: problemi di configurazione E1 July 23, 2014 01:19PM |
Re: problemi di configurazione E1 July 23, 2014 02:00PM |
#if MOTHERBOARD == 33 || MOTHERBOARD == 34 || MOTHERBOARD == 77 ----- ----- ----- #define E0_STEP_PIN 26 #define E0_DIR_PIN 28 #define E0_ENABLE_PIN 24 #define E1_STEP_PIN 36 #define E1_DIR_PIN 34 #define E1_ENABLE_PIN 30Secondo me ti è sufficiente invertire i numeri che ho copiato dal mio marlin quindi di default in
#define E0_STEP_PIN 36 #define E0_DIR_PIN 34 #define E0_ENABLE_PIN 30 #define E1_STEP_PIN 26 #define E1_DIR_PIN 28 #define E1_ENABLE_PIN 24
Re: problemi di configurazione E1 July 23, 2014 03:54PM |
**************************************************************************************** * Arduino Mega pin assignment * ****************************************************************************************/ #if MOTHERBOARD == 3 || MOTHERBOARD == 33 || MOTHERBOARD == 34 || MOTHERBOARD == 35 || MOTHERBOARD == 77 || MOTHERBOARD == 67 || MOTHERBOARD == 68 #define KNOWN_BOARD 1 //////////////////FIX THIS////////////// #ifndef __AVR_ATmega1280__ #ifndef __AVR_ATmega2560__ #error Oops! Make sure you have 'Arduino Mega' selected from the 'Tools -> Boards' menu. #endif #endif // uncomment one of the following lines for RAMPS v1.3 or v1.0, comment both for v1.2 or 1.1 // #define RAMPS_V_1_3 // #define RAMPS_V_1_0 #if MOTHERBOARD == 33 || MOTHERBOARD == 34 || MOTHERBOARD == 35 || MOTHERBOARD == 77 || MOTHERBOARD == 67 || MOTHERBOARD == 68 #define LARGE_FLASH true #if MOTHERBOARD == 77 #define X_STEP_PIN 54 #define X_DIR_PIN 55 #define X_ENABLE_PIN 38 #define X_MIN_PIN 3 #define X_MAX_PIN -1 //2 //Max endstops default to disabled "-1", set to commented value to enable. #define Y_STEP_PIN 60 #define Y_DIR_PIN 61 #define Y_ENABLE_PIN 56 #define Y_MIN_PIN 14 #define Y_MAX_PIN -1 //15 #define Z_STEP_PIN 46 #define Z_DIR_PIN 48 #define Z_ENABLE_PIN 63 #define Z_MIN_PIN 18 #define Z_MAX_PIN -1 #define Y2_STEP_PIN 36 #define Y2_DIR_PIN 34 #define Y2_ENABLE_PIN 30 #define Z2_STEP_PIN 36 #define Z2_DIR_PIN 34 #define Z2_ENABLE_PIN 30 #define E0_STEP_PIN 26 #define E0_DIR_PIN 28 #define E0_ENABLE_PIN 24 #define E1_STEP_PIN 36 #define E1_DIR_PIN 34 #define E1_ENABLE_PIN 30
Re: problemi di configurazione E1 July 23, 2014 05:09PM |
Re: problemi di configurazione E1 July 24, 2014 03:46AM |
#if MOTHERBOARD == 77devi cambiare i numeri dopo l'else..
#else
#define X_MIN_PIN 3
#define X_MAX_PIN 2
#define Y_MAX_PIN 15
#define Z_ENABLE_PIN 62
#define Z_MAX_PIN 19
