Problema Bed Leveling e consigli generali sulla qualità di stampa September 16, 2014 10:51AM |
//============================= Bed Auto Leveling =========================== #define ENABLE_AUTO_BED_LEVELING // Delete the comment to enable (remove // at the start of the line) #define Z_PROBE_REPEATABILITY_TEST // If not commented out, Z-Probe Repeatability test will be included if Auto Bed Leveling is Enabled. #ifdef ENABLE_AUTO_BED_LEVELING // There are 2 different ways to pick the X and Y locations to probe: // - "grid" mode // Probe every point in a rectangular grid // You must specify the rectangle, and the density of sample points // This mode is preferred because there are more measurements. // It used to be called ACCURATE_BED_LEVELING but "grid" is more descriptive // - "3-point" mode // Probe 3 arbitrary points on the bed (that aren't colinear) // You must specify the X & Y coordinates of all 3 points #define AUTO_BED_LEVELING_GRID // with AUTO_BED_LEVELING_GRID, the bed is sampled in a // AUTO_BED_LEVELING_GRID_POINTSxAUTO_BED_LEVELING_GRID_POINTS grid // and least squares solution is calculated // Note: this feature occupies 10'206 byte #ifdef AUTO_BED_LEVELING_GRID // set the rectangle in which to probe #define LEFT_PROBE_BED_POSITION 30 #define RIGHT_PROBE_BED_POSITION 190 #define BACK_PROBE_BED_POSITION 190 #define FRONT_PROBE_BED_POSITION 30 // set the number of grid points per dimension // I wouldn't see a reason to go above 3 (=9 probing points on the bed) #define AUTO_BED_LEVELING_GRID_POINTS 2 #else // not AUTO_BED_LEVELING_GRID // with no grid, just probe 3 arbitrary points. A simple cross-product // is used to esimate the plane of the print bed #define ABL_PROBE_PT_1_X 15 #define ABL_PROBE_PT_1_Y 180 #define ABL_PROBE_PT_2_X 15 #define ABL_PROBE_PT_2_Y 20 #define ABL_PROBE_PT_3_X 170 #define ABL_PROBE_PT_3_Y 20 #endif // AUTO_BED_LEVELING_GRID // these are the offsets to the probe relative to the extruder tip (Hotend - Probe) #define X_PROBE_OFFSET_FROM_EXTRUDER 30 #define Y_PROBE_OFFSET_FROM_EXTRUDER 5 #define Z_PROBE_OFFSET_FROM_EXTRUDER -6,41 #define Z_RAISE_BEFORE_HOMING 5 // (in mm) Raise Z before homing (G28) for Probe Clearance. // Be sure you have this distance over your Z_MAX_POS in case #define XY_TRAVEL_SPEED 5000 // X and Y axis travel speed between probes, in mm/min #define Z_RAISE_BEFORE_PROBING 5 //How much the extruder will be raised before traveling to the first probing point. #define Z_RAISE_BETWEEN_PROBINGS 5 //How much the extruder will be raised when traveling from between next probing points //#define Z_PROBE_SLED // turn on if you have a z-probe mounted on a sled like those designed by Charles Bell //#define SLED_DOCKING_OFFSET 5 // the extra distance the X axis must travel to pickup the sled. 0 should be fine but you can push it further if you'd like. //If defined, the Probe servo will be turned on only during movement and then turned off to avoid jerk //The value is the delay to turn the servo off after powered on - depends on the servo speed; 300ms is good value, but you can try lower it. // You MUST HAVE the SERVO_ENDSTOPS defined to use here a value higher than zero otherwise your code will not compile. //#define PROBE_SERVO_DEACTIVATION_DELAY 300 //If you have enabled the Bed Auto Leveling and are using the same Z Probe for Z Homing, //it is highly recommended you let this Z_SAFE_HOMING enabled!!! #define Z_SAFE_HOMING // This feature is meant to avoid Z homing with probe outside the bed area. // When defined, it will: // - Allow Z homing only after X and Y homing AND stepper drivers still enabled // - If stepper drivers timeout, it will need X and Y homing again before Z homing // - Position the probe in a defined XY point before Z Homing when homing all axis (G28) // - Block Z homing only when the probe is outside bed area. #ifdef Z_SAFE_HOMING #define Z_SAFE_HOMING_X_POINT (X_MAX_LENGTH/2) // X point for Z homing when homing all axis (G28) #define Z_SAFE_HOMING_Y_POINT (Y_MAX_LENGTH/2) // Y point for Z homing when homing all axis (G28) #endif #endif // ENABLE_AUTO_BED_LEVELINGEdited 1 time(s). Last edit at 09/23/2014 10:52AM by enricodare.
Re: Problema Bed Leveling e consigli generali sulla qualità di stampa September 16, 2014 02:51PM |
Re: Problema Bed Leveling e consigli generali sulla qualità di stampa September 16, 2014 03:39PM |
Re: Problema Bed Leveling e consigli generali sulla qualità di stampa September 23, 2014 07:01AM |
Re: Problema Bed Leveling e consigli generali sulla qualità di stampa September 23, 2014 07:30AM |
Re: Problema Bed Leveling e consigli generali sulla qualità di stampa September 23, 2014 09:04AM |
Re: Problema Bed Leveling e consigli generali sulla qualità di stampa September 23, 2014 09:15AM |
Moderator Registered: 11 years ago Posts: 1,865 |
Re: Problema Bed Leveling e consigli generali sulla qualità di stampa September 23, 2014 10:38AM |
Re: Problema Bed Leveling e consigli generali sulla qualità di stampa September 23, 2014 11:49AM |
Re: Problema Bed Leveling e consigli generali sulla qualità di stampa September 23, 2014 11:52AM |
Re: Problema Bed Leveling e consigli generali sulla qualità di stampa September 23, 2014 11:55AM |
Re: Problema Bed Leveling e consigli generali sulla qualità di stampa September 23, 2014 01:07PM |
Re: Problema Bed Leveling e consigli generali sulla qualità di stampa September 23, 2014 01:59PM |
Re: Problema Bed Leveling e consigli generali sulla qualità di stampa September 23, 2014 05:19PM |
Re: Problema Bed Leveling e consigli generali sulla qualità di stampa September 25, 2014 06:38AM |
Re: Problema Bed Leveling e consigli generali sulla qualità di stampa September 25, 2014 07:09AM |
