ABL....con la guida tutto ok, ma dopo..... March 20, 2015 04:36PM |
Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density} ;Print time: {print_time} ;Filament used: {filament_amount}m {filament_weight}g ;Filament cost: {filament_cost} M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line M109 S{print_temperature} ;Uncomment to add your own temperature line G21 ;metric values G90 ;absolute positioning M82 ;set extruder to absolute mode M107 ;start with the fan off G28 X0 Y0 ;move X/Y to min endstops G28 ;move Z to min endstops G29 ;Auto Bed Leveling G1 Z15.0 F{travel_speed} ;move the platform down 15mm G92 E0 ;zero the extruded length G1 F200 E3 ;extrude 3mm of feed stock G92 E0 ;zero the extruded length again G1 F{travel_speed} ;Put printing message on LCD screen M117 Printing...
Re: ABL....con la guida tutto ok, ma dopo..... March 25, 2015 04:52PM |
Re: ABL....con la guida tutto ok, ma dopo..... March 25, 2015 05:11PM |
Re: ABL....con la guida tutto ok, ma dopo..... March 25, 2015 06:17PM |
[RISOLTO - quasi] ABL....con la guida tutto ok, ma dopo..... April 28, 2015 03:43PM |
Se è tutto ok passiamo alla seconda fase.
Prima di tutto diamo il comando G28 X0 Y0 e poi il comando G29, a questo punto dopo la home di X e Y la sonda comincerà a fare il suo lavoro o nella griglia o nei punti decisi.
Re: [RISOLTO - quasi] ABL....con la guida tutto ok, ma dopo..... April 28, 2015 05:18PM |
Re: ABL....con la guida tutto ok, ma dopo..... April 28, 2015 05:34PM |
SENDING:M119 Reporting endstop status x_min: open y_min: open z_min: open >>> m119 SENDING:M119 Reporting endstop status x_min: open y_min: open z_min: TRIGGERED
Re: ABL....con la guida tutto ok, ma dopo..... April 28, 2015 05:54PM |
#define LEFT_PROBE_BED_POSITION 50 #define RIGHT_PROBE_BED_POSITION 120 #define BACK_PROBE_BED_POSITION 150 #define FRONT_PROBE_BED_POSITION 30
#define X_PROBE_OFFSET_FROM_EXTRUDER -50
Re: ABL....con la guida tutto ok, ma dopo..... April 28, 2015 06:57PM |
MagoKimbra
ok ora se subito dopo al g28 cosi com'è dai g29 dovrebbe spostarsi nel primo angolo....
Re: ABL....con la guida tutto ok, ma dopo..... April 28, 2015 07:02PM |
Re: ABL....con la guida tutto ok, ma dopo..... April 29, 2015 05:10AM |
Re: ABL....con la guida tutto ok, ma dopo..... April 29, 2015 05:56AM |
Re: ABL....con la guida tutto ok, ma dopo..... April 29, 2015 03:56PM |
sanitycheck.h:198:10: error: #error The Y axis probing range is too small to fit all the points defined in AUTO_BED_LEVELING_GRID_POINTS #error The Y axis probing range is too small to fit all the points defined in AUTO_BED_LEVELING_GRID_POINTS ^ In file included from cardreader.cpp:1:0: Marlin.h:48:26: fatal error: Comunication.h: File o directory non esistente #include "Comunication.h" ^ compilation terminated.
Re: ABL....con la guida tutto ok, ma dopo..... April 29, 2015 04:16PM |
#define ABL_PROBE_PT_1_X 15 #define ABL_PROBE_PT_1_Y 180 #define ABL_PROBE_PT_2_X 15 #define ABL_PROBE_PT_2_Y 20 #define ABL_PROBE_PT_3_X 170 #define ABL_PROBE_PT_3_Y 20
Re: ABL....con la guida tutto ok, ma dopo..... April 29, 2015 04:40PM |
Moderator Registered: 11 years ago Posts: 1,865 |
Re: ABL....con la guida tutto ok, ma dopo..... April 29, 2015 05:05PM |
Re: ABL....con la guida tutto ok, ma dopo..... April 29, 2015 05:14PM |
Re: ABL....con la guida tutto ok, ma dopo..... April 29, 2015 07:55PM |
Re: ABL....con la guida tutto ok, ma dopo..... April 30, 2015 02:24AM |
Re: ABL....con la guida tutto ok, ma dopo..... April 30, 2015 06:10AM |
MagoKimbra
Allora prima dell'ABL se hai il min stop a destra e Y min stop dietro avrai le stampe specchiate, Come mai hai fatto così????
Se proprio devi mettere lo switch endstop a destra allora è un Max end stop.....
MagoKimbra
I valori 170 x 180 sono il massimo che può scorrere ogni asse?????
Re: ABL....con la guida tutto ok, ma dopo..... April 30, 2015 11:57AM |
Re: ABL....con la guida tutto ok, ma dopo..... May 01, 2015 09:08AM |
Re: ABL....con la guida tutto ok, ma dopo..... May 01, 2015 09:27AM |
#define Z_SAFE_HOMING_X_POINT (X_MAX_LENGTH/2) #define Z_SAFE_HOMING_Y_POINT (Y_MAX_LENGTH/2)
Re: ABL....con la guida tutto ok, ma dopo..... May 01, 2015 11:02AM |
MagoKimbra
Ma la sonda è a sinistra e avanti rispetto al Nozzle???
#define X_PROBE_OFFSET_FROM_EXTRUDER 52 // Probe on: -left +right
Re: ABL....con la guida tutto ok, ma dopo..... May 01, 2015 11:28AM |
Re: ABL....con la guida tutto ok, ma dopo..... May 01, 2015 03:43PM |
Re: ABL....con la guida tutto ok, ma dopo..... May 01, 2015 06:01PM |
Re: ABL....con la guida tutto ok, ma dopo..... May 02, 2015 09:29AM |
MagoKimbra
A scusa avevo letto un'altra cosa...
Ok dopo aver fatto G28 dai il comando M114 e vedi che Z ti restituisce. Dovrebbe essere il valore dell'offset Z....
SENDING:G29 : G29 Auto Bed Leveling : Eqn coefficients: a: 0.00063846 b: -0.00377917 d: 1.51525030 : planeNormal x: -0.000638 y: 0.003779 z: 1.000000 : Bed Level Correction Matrix: : +1.000000 +0.000000 +0.000638 : +0.000002 +0.999993 -0.003779 : -0.000638 +0.003779 +0.999993
Re: ABL....con la guida tutto ok, ma dopo..... May 02, 2015 11:10AM |
Re: ABL....con la guida tutto ok, ma dopo..... May 02, 2015 11:45AM |
MagoKimbra
Due domandine...
Dopo aver fatto g28 hai detto che dando M114 ti dice che si trova a 49,9 (che è il tuo offset) quindi il nozzle è a quasi 5cm dal piatto giusto? Se gli dici di andare a 60 G1 Z60 sale?
SENDING:G28 >>> m114 SENDING:M114 ok X:38.00 Y:95.00 Z:49.90 E:0.00 Count X: 38.00 Y:95.00 Z:49.90
MagoKimbra
SENDING:G28 X0 Y0 >>> g29 SENDING:G29 : G29 Auto Bed Leveling : Eqn coefficients: a: 0.00164033 b: -0.00313646 d: 51.07441329 : planeNormal x: -0.001640 y: 0.003136 z: 1.000000 : Bed Level Correction Matrix: : +0.999999 +0.000000 +0.001640 : +0.000005 +0.999995 -0.003136 : -0.001640 +0.003136 +0.999994
