Attivazione Heated bed February 27, 2020 03:55AM |
Re: Attivazione Heated bed February 27, 2020 04:29AM |
#define TEMP_SENSOR_BED 0
/* Below you will find the configuration string, that created with Configurator tool online marlinkimbra.it ========== Start configuration string ==========
"bed": "1", .... "tempsensorbed": "0", ..... "pidbedtemp": "1", ..... "heaterbedpin": "ORIG_HEATER_BED_PIN", .... "tempbedpin": "ORIG_TEMP_BED_PIN",
"motherboards": "BOARD_RAMPS_13_HFB",
/** * RAMPS 1.3 / 1.4 - ATmega1280, ATmega2560 */ #define BOARD_RAMPS_OLD 3 // MEGA/RAMPS up to 1.2 #define BOARD_RAMPS_13_HFB 33 // RAMPS 1.3 / 1.4 (Power outputs: Hotend, Fan, Bed) #define BOARD_RAMPS_13_HHB 34 // RAMPS 1.3 / 1.4 (Power outputs: Hotend0, Hotend1, Bed) #define BOARD_RAMPS_13_HFF 35 // RAMPS 1.3 / 1.4 (Power outputs: Hotend, Fan, Fan) #define BOARD_RAMPS_13_HHF 36 // RAMPS 1.3 / 1.4 (Power outputs: Hotend0, Hotend1, Fan) #define BOARD_RAMPS_13_HHH 37 // RAMPS 1.3 / 1.4 (Power outputs: Hotend0, Hotend1, Hotend2)
//###TEMPERATURE #define ORIG_TEMP_0_PIN 13 #define ORIG_TEMP_1_PIN 15 #define ORIG_TEMP_2_PIN NoPin #define ORIG_TEMP_3_PIN NoPin #define ORIG_TEMP_BED_PIN 14 #define ORIG_TEMP_CHAMBER_PIN NoPin #define ORIG_TEMP_COOLER_PIN NoPin
//###HEATER #define ORIG_HEATER_0_PIN 10 #define ORIG_HEATER_1_PIN NoPin #define ORIG_HEATER_2_PIN NoPin #define ORIG_HEATER_3_PIN NoPin #define ORIG_HEATER_BED_PIN 8 #define ORIG_HEATER_CHAMBER_PIN NoPin #define ORIG_COOLER_PIN NoPin
Re: Attivazione Heated bed February 27, 2020 01:26PM |
Re: Attivazione Heated bed February 27, 2020 02:17PM |
Re: Attivazione Heated bed February 27, 2020 05:03PM |
Re: Attivazione Heated bed February 28, 2020 06:27AM |
Re: Attivazione Heated bed February 28, 2020 11:52AM |
