auto bed level e altezza errata April 24, 2015 04:15AM |
Bed x: 25.00 y: 20.00 z: 1.41 Bed x: 170.00 y: 20.00 z: 1.35 Bed x: 170.00 y: 160.00 z: 1.74 Bed x: 25.00 y: 160.00 z: 1.53
G28 X0 Y0 G29 G1 X25 Y160 F8000 G1 Z10 F3000 G1 Z0 F3000 etc per tutti i punti..
Re: auto bed level e altezza errata April 24, 2015 04:20PM |
21:51:07.729 : Bed x: 25.00 y: 20.00 z: -8.76 21:51:20.668 : Bed x: 170.00 y: 20.00 z: -8.84 21:51:33.353 : Bed x: 170.00 y: 160.00 z: -8.42 21:51:46.361 : Bed x: 25.00 y: 160.00 z: -8.64 21:51:46.369 : Eqn coefficients: a: 0.00 b: 0.00 d: -8.89 21:51:46.373 : planeNormal x: -0.00 y: -0.00 z: 1.00
21:53:36.182 : Bed x: 25.00 y: 20.00 z: 1.50 21:53:49.100 : Bed x: 170.00 y: 20.00 z: 1.46 21:54:01.785 : Bed x: 170.00 y: 160.00 z: 1.89 21:54:14.773 : Bed x: 25.00 y: 160.00 z: 1.70 21:54:14.781 : Eqn coefficients: a: 0.00 b: 0.00 d: 1.38 21:54:14.785 : planeNormal x: -0.00 y: -0.00 z: 1.00è normale che l'asse Z cambi così tanto?
Re: auto bed level e altezza errata April 24, 2015 06:14PM |
Re: auto bed level e altezza errata April 25, 2015 07:22AM |
Re: auto bed level e altezza errata April 25, 2015 09:18AM |
Re: auto bed level e altezza errata April 25, 2015 10:52AM |
Re: auto bed level e altezza errata April 25, 2015 11:54AM |
Re: auto bed level e altezza errata April 25, 2015 12:24PM |
Re: auto bed level e altezza errata April 25, 2015 12:29PM |
Re: auto bed level e altezza errata April 30, 2015 07:12PM |
Re: auto bed level e altezza errata May 01, 2015 03:35AM |
Re: auto bed level e altezza errata May 04, 2015 04:25PM |
#define ABL_PROBE_PT_4_X 170 #define ABL_PROBE_PT_4_Y 20 ..
Re: auto bed level e altezza errata May 04, 2015 05:42PM |
Re: auto bed level e altezza errata May 04, 2015 06:20PM |
Re: auto bed level e altezza errata May 04, 2015 06:39PM |
Re: auto bed level e altezza errata May 05, 2015 02:59AM |
Re: auto bed level e altezza errata May 05, 2015 03:37AM |
Re: auto bed level e altezza errata May 05, 2015 06:49PM |
Re: auto bed level e altezza errata May 06, 2015 02:53AM |
#ifdef AUTO_BED_LEVELING_GRID // Check if Probe_Offset * Grid Points is greater than Probing Range #if X_PROBE_OFFSET_FROM_EXTRUDER < 0 #if (-(X_PROBE_OFFSET_FROM_EXTRUDER * AUTO_BED_LEVELING_GRID_POINTS) >= (RIGHT_PROBE_BED_POSITION - LEFT_PROBE_BED_POSITION)) #error "The X axis probing range is not enough to fit all the points defined in AUTO_BED_LEVELING_GRID_POINTS" #endif #else #if ((X_PROBE_OFFSET_FROM_EXTRUDER * AUTO_BED_LEVELING_GRID_POINTS) >= (RIGHT_PROBE_BED_POSITION - LEFT_PROBE_BED_POSITION)) #error "The X axis probing range is not enough to fit all the points defined in AUTO_BED_LEVELING_GRID_POINTS" #endif #endif #if Y_PROBE_OFFSET_FROM_EXTRUDER < 0 #if (-(Y_PROBE_OFFSET_FROM_EXTRUDER * AUTO_BED_LEVELING_GRID_POINTS) >= (BACK_PROBE_BED_POSITION - FRONT_PROBE_BED_POSITION)) #error "The Y axis probing range is not enough to fit all the points defined in AUTO_BED_LEVELING_GRID_POINTS" #endif #else #if ((Y_PROBE_OFFSET_FROM_EXTRUDER * AUTO_BED_LEVELING_GRID_POINTS) >= (BACK_PROBE_BED_POSITION - FRONT_PROBE_BED_POSITION)) #error "The Y axis probing range is not enough to fit all the points defined in AUTO_BED_LEVELING_GRID_POINTS" #endif #endif
Re: auto bed level e altezza errata May 06, 2015 07:02PM |
Re: auto bed level e altezza errata May 07, 2015 09:04AM |
