Re: Ramps-FD e LCD 12864 RepRap Full Graphic FW MarlinKimbra4due May 26, 2015 02:30AM |
Re: Ramps-FD e LCD 12864 RepRap Full Graphic FW MarlinKimbra4due May 26, 2015 02:55AM |
Ok quindi scaricandolo dal Autoconfiguratore On-Line tiro giù già la versione con le modifiche citate esatto ?Quote
MagoKimbra
Il configuratore on line prende i file da github quelli nel branch master quindi sono uguali.
Re: Ramps-FD e LCD 12864 RepRap Full Graphic FW MarlinKimbra4due May 26, 2015 03:07AM |
Re: Ramps-FD e LCD 12864 RepRap Full Graphic FW MarlinKimbra4due May 26, 2015 03:11AM |
Re: Ramps-FD e LCD 12864 RepRap Full Graphic FW MarlinKimbra4due May 26, 2015 04:28AM |
Re: Ramps-FD e LCD 12864 RepRap Full Graphic FW MarlinKimbra4due May 26, 2015 05:57AM |
#ifdef ULTRA_LCD #ifdef NEWPANEL // ramps-fd lcd adaptor #define LCD_PINS_RS 16 #define LCD_PINS_ENABLE 17 #define LCD_PINS_D4 23 #define LCD_PINS_D5 25 #define LCD_PINS_D6 27 #define LCD_PINS_D7 29 #ifdef REPRAP_DISCOUNT_SMART_CONTROLLER #define BEEPER 37 #define BTN_EN1 33 #define BTN_EN2 31 #define BTN_ENC 35 #define SDCARDDETECT 49 #endif #endif #endif //ULTRA_LCD
09 D37 > BEEP 10 D35 > ENC_SW 11 D33 > ENC1 12 D31 > ENC2 13 D29 <74HC07A> LCD_D7 14 D27 <74HC07A> LCD D6 15 D25 <74HC07A> LCD D5 16 D23 <74HC07A> LCD D4 17 UART2_RX_LV <74HC07A> LCD E D17 18 UART_TX_LV <74HC07A> LCD RS D16
Re: Ramps-FD e LCD 12864 RepRap Full Graphic FW MarlinKimbra4due May 26, 2015 08:18AM |
Si lo vedo e lo sto constatando anche su RFw sembrano gli stessi PIN mappatiQuote
MagoKimbra
Beeper 37 OK
D4 23 Ok
LCD_ENABLE 17 OK
LCD_RS 16 OK
ENC1 33 OK
ENC2 31 OK
ENC_SW 35 OK
Come vedi stanno tutti bene....
Re: Ramps-FD e LCD 12864 RepRap Full Graphic FW MarlinKimbra4due May 26, 2015 08:34AM |
Re: Ramps-FD e LCD 12864 RepRap Full Graphic FW MarlinKimbra4due May 26, 2015 09:15AM |
campe89
Sia Repetier sia Marlin hanno bisogno solo del pin D4; io di fatti gli altri li ho scollegati.
#define LCD_PINS_RS 17 #define LCD_PINS_ENABLE 16 #define LCD_PINS_D4 25 #define LCD_PINS_D5 23 #define LCD_PINS_D6 29 #define LCD_PINS_D7 27
Re: Ramps-FD e LCD 12864 RepRap Full Graphic FW MarlinKimbra4due May 27, 2015 02:16AM |
Re: Ramps-FD e LCD 12864 RepRap Full Graphic FW MarlinKimbra4due May 27, 2015 02:34AM |
Re: Ramps-FD e LCD 12864 RepRap Full Graphic FW MarlinKimbra4due May 27, 2015 01:07PM |
Re: Ramps-FD e LCD 12864 RepRap Full Graphic FW MarlinKimbra4due May 27, 2015 02:28PM |
Re: Ramps-FD e LCD 12864 RepRap Full Graphic FW MarlinKimbra4due May 27, 2015 03:03PM |
Re: Ramps-FD e LCD 12864 RepRap Full Graphic FW MarlinKimbra4due May 27, 2015 03:14PM |
Re: Ramps-FD e LCD 12864 RepRap Full Graphic FW MarlinKimbra4due May 27, 2015 03:40PM |
Re: Ramps-FD e LCD 12864 RepRap Full Graphic FW MarlinKimbra4due May 27, 2015 04:53PM |
Straquoto! Quando metti su una piattaforma per le donazioni? Ti devo almeno un paio di birreQuote
saviothecnic
Confermo che sei un Mago
Re: Ramps-FD e LCD 12864 RepRap Full Graphic FW MarlinKimbra4due May 27, 2015 06:35PM |
Vedi che nel Link MarlinKimba già ci sta il pulsante DonazioneQuote
campe89
Perche hai una Delta ?Quote
campe89
Tornando a noi: mi dici che devi rallentare in modo considerevole la velocità di questi lcd, ma questo vuol dire che poi tutto questo si riperquote sulla velocità di stampa da sd? Perché fondamentalmente si usa il controller quasi solo per questo, e almeno nel mio caso, non ci sarebbe più vantaggio ad usare arduino due..Con la Alligator come si comporta?
Re: Ramps-FD e LCD 12864 RepRap Full Graphic FW MarlinKimbra4due May 27, 2015 06:46PM |
Re: Ramps-FD e LCD 12864 RepRap Full Graphic FW MarlinKimbra4due May 28, 2015 02:20AM |
Non ancora ma è work in progress, vedi firma.Quote
saviothecnic
Eh no quà ti sbagli: gli adattatori di livello servono proprio solo per la SD..guarda lo schema..Quote
saviothecnic
Comunque credo di NO al max ci puo essere un problema di refresh sul LCD anche la gestione SD dovrebbe essere OK perche non passa per gli adattatori di livello
Re: Ramps-FD e LCD 12864 RepRap Full Graphic FW MarlinKimbra4due May 28, 2015 03:13AM |
Hai ragione vedevo solo quello della Ramps FD e quello del Adattatore LCD e li non era presente nella parte SD mentre ovviamente è presente nel Modulo LCD/SDQuote
campe89
Questo sarebbe una figata da usare ma mi sa frega troppi PIN credo sia piu saggio trovare qualcosa che usa solo 4 pin scruttando I2C
Re: Ramps-FD e LCD 12864 RepRap Full Graphic FW MarlinKimbra4due May 28, 2015 05:28PM |
Re: Ramps-FD e LCD 12864 RepRap Full Graphic FW MarlinKimbra4due May 29, 2015 02:37AM |
previous_lcd_status_ms = millis(); //get status message to show up for a while
Re: Ramps-FD e LCD 12864 RepRap Full Graphic FW MarlinKimbra4due May 29, 2015 02:39AM |
Re: Ramps-FD e LCD 12864 RepRap Full Graphic FW MarlinKimbra4due May 29, 2015 02:49AM |
Re: Ramps-FD e LCD 12864 RepRap Full Graphic FW MarlinKimbra4due May 29, 2015 02:57AM |
Re: Ramps-FD e LCD 12864 RepRap Full Graphic FW MarlinKimbra4due May 29, 2015 03:06AM |
Re: Ramps-FD e LCD 12864 RepRap Full Graphic FW MarlinKimbra4due May 29, 2015 04:14AM |
Re: Ramps-FD e LCD 12864 RepRap Full Graphic FW MarlinKimbra4due May 29, 2015 04:35AM |
Re: Ramps-FD e LCD 12864 RepRap Full Graphic FW MarlinKimbra4due May 29, 2015 04:47AM |
Ho la stampante mezza smontata per via dei lavori piano ribassato e flusso canalizzatoreQuote
campe89
Savio puoi verificare se poi di fatto lanciando un gcode da sd la stampa parte?
Ok GrazieQuote
campe89
Provo a risponderti per le domande precedenti:
Si lo so era solo per conferma su Ramps 1.4 ho settato cosiQuote
campe89
Usando i DRV8823 per 1/32 setto 1 2 3 chiuso per 1/8 1 2 chiusi e 3 aperto fai riferimento a quanto scritto qui [www.pololu.com] sotto trovi la tabella
Be su questo spero il Mago sappia consigliarmiQuote
campe89
In caso si selezione un solo HE e tre estrusori Extruder FAN posso usare un solo connettore tipo non l'ho capita
Swtich rele estrusori : credo va bene uno digitale mai usato, non saprei
Sensore diametro filamento : presumo ne serve uno analogico mai usato, non saprei
Sensore autotaratura piatto qui presumo uso lo Z min che non ho pero inteso bene quale pin sia si devi usare il classico pin degli endstop
Sensore consumo corrente : presumo ne serve uno analogico mai usato, non saprei
