(RISOLTO)Piatto non programmabile oltre 105 gradi June 03, 2015 09:39AM |
Re: Piatto non programmabile oltre 105 gradi June 03, 2015 09:49AM |
#define BED_MAXTEMP 150 // (degC)
Re: Piatto non programmabile oltre 105 gradi June 03, 2015 10:13AM |
Re: Piatto non programmabile oltre 105 gradi June 03, 2015 10:18AM |
Re: Piatto non programmabile oltre 105 gradi June 03, 2015 10:51AM |
MENU_MULTIPLIER_ITEM_EDIT(int3, MSG_BED, &target_temperature_bed, 0, BED_MAXTEMP
Re: Piatto non programmabile oltre 105 gradi June 03, 2015 11:44AM |
Moderator Registered: 11 years ago Posts: 1,865 |
Re: Piatto non programmabile oltre 105 gradi June 03, 2015 11:51AM |
Re: (RISOLTO)Piatto non programmabile oltre 105 gradi June 03, 2015 11:55AM |
Re: (RISOLTO)Piatto non programmabile oltre 105 gradi June 03, 2015 12:00PM |
static void lcd_tune_menu() { START_MENU(lcd_main_menu); MENU_ITEM(back, MSG_MAIN, lcd_main_menu); MENU_ITEM_EDIT(int3, MSG_SPEED, &feedrate_multiplier, 10, 999); #if TEMP_SENSOR_0 != 0 MENU_MULTIPLIER_ITEM_EDIT(int3, MSG_NOZZLE, &target_temperature[0], 0, HEATER_0_MAXTEMP + LCD_MAX_TEMP_OFFSET); #endif #if TEMP_SENSOR_1 != 0 MENU_MULTIPLIER_ITEM_EDIT(int3, MSG_NOZZLE " 2", &target_temperature[1], 0, HEATER_1_MAXTEMP + LCD_MAX_TEMP_OFFSET); #endif #if TEMP_SENSOR_2 != 0 MENU_MULTIPLIER_ITEM_EDIT(int3, MSG_NOZZLE " 3", &target_temperature[2], 0, HEATER_2_MAXTEMP + LCD_MAX_TEMP_OFFSET); #endif #if TEMP_SENSOR_3 != 0 MENU_MULTIPLIER_ITEM_EDIT(int3, MSG_NOZZLE " 4", &target_temperature[3], 0, HEATER_3_MAXTEMP + LCD_MAX_TEMP_OFFSET); #endif #if TEMP_SENSOR_BED != 0 MENU_MULTIPLIER_ITEM_EDIT(int3, MSG_BED, &target_temperature_bed, 0, BED_MAXTEMP + LCD_MAX_TEMP_OFFSET);
