Errore avr-gcc November 22, 2015 08:22AM |
avr-gcc: error: core.a: No such file or directory Errore durante la compilazione
Re: Errore avr-gcc November 22, 2015 08:48AM |
Re: Errore avr-gcc November 22, 2015 08:53AM |
Delta
Ma scusa quel FW non è per 32bit?
Re: Errore avr-gcc November 23, 2015 09:26AM |
In file included from sketch/dogm_lcd_implementation.h:54:0, from sketch/ultralcd.cpp:50: sketch/dogm_font_data_Marlin_symbols.h:12:25: fatal error: utility/u8g.h: No such file or directory #include ^ compilation terminated. exit status 1 Errore durante la compilazione
Re: Errore avr-gcc November 25, 2015 11:01AM |
Re: Errore avr-gcc November 27, 2015 02:36PM |
ninjamcrew
Ciao, io proverei a reinstallare l'IDE di arduino perche' solo ieri ho scaricato il fw come hai fatto tu e con la versione v1.6.5 dell'IDE compila tutto perfettamente.
ciao
Re: Errore avr-gcc March 04, 2016 08:22AM |
Re: Errore avr-gcc March 04, 2016 09:02AM |
Re: Errore avr-gcc March 04, 2016 09:22AM |
MagoKimbra
Scrivi che errore ti da...
In file included from dogm_lcd_implementation.h:54:0, from ultralcd.cpp:50: dogm_font_data_Marlin_symbols.h:12:25: fatal error: utility/u8g.h: No such file or directory #include ^ compilation terminated. Error compiling.
Re: Errore avr-gcc March 04, 2016 09:30AM |
#include < U8glib.h >
Re: Errore avr-gcc March 04, 2016 10:02AM |
MagoKimbra
Bho!!!
Apri il file dogm_font_data_Marlin_symbols.h e alla riga #include < utility/u8g.h > sostituiscila con
Edit non mettere gli spazi tra il maggiore o minore e il testo, l'ho dovuto aggiungere qui sul forum altrimenti sparisce tutto.
In file included from sketch\dogm_lcd_implementation.h:54:0, from sketch\ultralcd.cpp:50: sketch\dogm_font_data_Marlin_symbols.h:12:28: fatal error: utility/U8glib.h: No such file or directory #include ^ compilation terminated. exit status 1 Error compiling.
Re: Errore avr-gcc March 04, 2016 10:07AM |
Re: Errore avr-gcc March 04, 2016 10:10AM |
Re: Errore avr-gcc March 04, 2016 11:04AM |
MagoKimbra
Il problema è che sono state aggiornate le lib U8g...
Prima avevano dei file nella cartella utility, adesso non più. Quindi prima ti andava bene perché avevi le vecchie librerie, adesso che hai le nuove non va..
Ma io ho aggiornato i file della 4.1.2 per essere compatibili con le nuove, ma tu ancora hai i vecchi file...
Re: Errore avr-gcc March 04, 2016 11:14AM |
Re: Errore avr-gcc March 04, 2016 02:50PM |
MagoKimbra
A meno che non rimetti le vecchie ogni volta che compili con i vecchi fw...
