MK4Duo per Hephestos modifiche firmware “importanti” per farlo funzionare October 11, 2016 07:00AM |
//#define CONFIGURATION_OVERALLE ho successivamente settato tutti i parametri in:
#error "Z_ENDSTOP_SERVO_NR must be less than NUM_SERVOS."Pur avendo settato I parametri in questo modo (credo in modo corretto)
// Z Servo Endstop // Remember active servos in Configuration_Feature.h // Define nr servo for endstop -1 not define. Servo index start 0 #define Z_ENDSTOP_SERVO_NR 0 #define Z_ENDSTOP_SERVO_ANGLES {11,180} // Z Servo Deploy and Stow angles
//#define AUTO_BED_LEVELING_3POINT #define AUTO_BED_LEVELING_LINEAR //#define AUTO_BED_LEVELING_BILINEAR /** * Enable detailed logging of G28, G29, G30, M48, etc. * Turn on with the command 'M111 S32'. * NOTE: Requires a lot of PROGMEM! */ //#define DEBUG_LEVELING_FEATURE /** if ENABLED(AUTO_BED_LEVELING_LINEAR) or ENABLED(AUTO_BED_LEVELING_BILINEAR) **/ // Set the number of grid points per dimension #define ABL_GRID_POINTS_X 2 #define ABL_GRID_POINTS_Y 2 // Set the boundaries for probing (where the probe can reach). #define LEFT_PROBE_BED_POSITION 40 #define RIGHT_PROBE_BED_POSITION 180 #define FRONT_PROBE_BED_POSITION 20 #define BACK_PROBE_BED_POSITION 132 // The Z probe minimum outer margin (to validate G29 parameters). #define MIN_PROBE_EDGE 10 // Probe along the Y axis, advancing X after each column #define PROBE_Y_FIRST /** END **/ /** if ENABLED(AUTO_BED_LEVELING_3POINT) **/ // 3 arbitrary points to probe. // A simple cross-product is used to estimate the plane of the bed. #define ABL_PROBE_PT_1_X 15 #define ABL_PROBE_PT_1_Y 180 #define ABL_PROBE_PT_2_X 15 #define ABL_PROBE_PT_2_Y 15 #define ABL_PROBE_PT_3_X 180 #define ABL_PROBE_PT_3_Y 15 /** END **/ /** * Commands to execute at the end of G29 probing. * Useful to retract or move the Z probe out of the way. */ #define Z_PROBE_END_SCRIPT "G1 Z10 F8000\nG1 X10 Y10\nG1 Z0.5"e in Configuration_Feature.h
#define ENABLE_SERVOS // Number of servos // If you select a configuration below, this will receive a default value and does not need to be set manually // set it manually if you have more servos than extruders and wish to manually control some // leaving it defining as 0 will disable the servo subsystem #define NUM_SERVOS 1 // Servo index starts with 0 for M280 command // // Servo deactivation // With this option servos are powered only during movement, then turned off to prevent jitter. #define DEACTIVATE_SERVOS_AFTER_MOVE // Delay (in microseconds) before turning the servo off. This depends on the servo speed. // 300ms is a good value but you can try less delay. // If the servo can't reach the requested position, increase it. #define SERVO_DEACTIVATION_DELAY 300Poi dopo svariati tentativi mi sono accorto che pur avendo
//#define CONFIGURATION_OVERALLSe non inserivo i valori anche all’intero del file configuration_overall.h continuava a uscirmi l’errore
#error "Z_ENDSTOP_SERVO_NR must be less than NUM_SERVOS."Quindi ho modificato il file base.h da cosi
#include "src/macros.h" #include "src/types.h" #include "Boards.h" #include "src/mechanics.h" #include "Configuration_Version.h" #ifndef CONFIGURATION_OVERALL #include "Configuration_Basic.h" #endif #include "Configuration_Overall.h" #ifndef CONFIGURATION_OVERALL #if MECH(CARTESIAN) #include "Configuration_Cartesian.h" #elif MECH(COREXY) #include "Configuration_Core.h" #elif MECH(COREYX) #include "Configuration_Core.h" #elif MECH(COREXZ) #include "Configuration_Core.h" #elif MECH(COREZX) #include "Configuration_Core.h" #elif MECH(DELTA) #include "Configuration_Delta.h" #elif MECH(SCARA) #include "Configuration_Scara.h" #endif #include "Configuration_Temperature.h" #include "Configuration_Feature.h" #include "Configuration_Overall.h" #endifA così
#include "src/macros.h" #include "src/types.h" #include "Boards.h" #include "src/mechanics.h" #include "Configuration_Version.h" #include "Configuration_Basic.h" #include "Configuration_Cartesian.h" #include "Configuration_Temperature.h" #include "Configuration_Feature.h"e il problema è sparito, ovvero adesso quando setto I valori in:
// Set the boundaries for probing (where the probe can reach). #define LEFT_PROBE_BED_POSITION 20 #define RIGHT_PROBE_BED_POSITION 180 #define FRONT_PROBE_BED_POSITION 20 #define BACK_PROBE_BED_POSITION 180Ovvero mi saltava fuori l’errore dal sanitycheck.h
#error "The given LEFT_PROBE_BED_POSITION can't be reached by the Z probe." #error "The given BACK_PROBE_BED_POSITION can't be reached by the Z probe."Facilmente risolvibile settando
// Set the boundaries for probing (where the probe can reach). #define LEFT_PROBE_BED_POSITION 40 (valore Massimo oltre scatta l’errore) #define RIGHT_PROBE_BED_POSITION 180 #define FRONT_PROBE_BED_POSITION 20 #define BACK_PROBE_BED_POSITION 132 (valore Massimo oltre scatta l’errore)Caricato tutto eseguito il G29 per ABL, il probe usa dei punti sia per i LEFT che per BACK molto “centrali” nel senso che ci sarebbe ampiamente del margine per settare valori più bassi per i LEFT e più alti per i BACK; quindi mi sono messo a fare una ricognizione nel sanitycheck.h per capire quale era il motivo per cui saltava fuori l’errore e ho visto che:
#if LEFT_PROBE_BED_POSITION < MIN_PROBE_X #error "The given LEFT_PROBE_BED_POSITION can't be reached by the Z probe." #elif BACK_PROBE_BED_POSITION > MAX_PROBE_Y #error "The given BACK_PROBE_BED_POSITION can't be reached by the Z probe." #endifOra la cosa che non capisco è:
#if LEFT_PROBE_BED_POSITION < MIN_PROBE_XQuindi il LEFT_PROBE_BED_POSITION è il valore che ho impostato e fin qui tutto ok ma MIN_PROBE_X da dove lo va a pescare? Che valore è? e dove lo trovo all’interno dei vari file?
Re: MK4Duo per Hephestos modifiche firmware “importanti” per farlo funzionare October 11, 2016 10:50AM |
Re: MK4Duo per Hephestos modifiche firmware “importanti” per farlo funzionare October 11, 2016 12:59PM |
Re: MK4Duo per Hephestos modifiche firmware “importanti” per farlo funzionare October 25, 2016 03:43PM |
