MarlinKimbra su Stratasys June 22, 2017 10:56AM |
Re: MarlinKimbra su Stratasys June 22, 2017 06:13PM |
Re: MarlinKimbra su Stratasys June 23, 2017 03:51AM |
Re: MarlinKimbra su Stratasys June 23, 2017 11:47AM |
Re: MarlinKimbra su Stratasys June 23, 2017 12:02PM |
In file included from sketch\src\../src/HAL/HAL.h:39:0, from sketch\src\../base.h:86, from sketch\src\MK_Main.cpp:31: sketch\src\MK_Main.cpp: In function 'void gcode_M355()': sketch\src\../src/HAL/HAL_DUE/communication.h:113:45: error: expected primary-expression before 'do' #define SERIAL_EM(msg) do{ SERIAL_M(msg); SERIAL_E; }while(0) ^ sketch\src\MK_Main.cpp:9010:21: note: in expansion of macro 'SERIAL_EM' case_light_on ? SERIAL_EM("on") : SERIAL_EM("off"); ^ sketch\src\../src/HAL/HAL_DUE/communication.h:113:45: error: expected ':' before 'do' #define SERIAL_EM(msg) do{ SERIAL_M(msg); SERIAL_E; }while(0) ^ sketch\src\MK_Main.cpp:9010:21: note: in expansion of macro 'SERIAL_EM' case_light_on ? SERIAL_EM("on") : SERIAL_EM("off"); ^ sketch\src\../src/HAL/HAL_DUE/communication.h:113:45: error: expected primary-expression before 'do' #define SERIAL_EM(msg) do{ SERIAL_M(msg); SERIAL_E; }while(0) ^ sketch\src\MK_Main.cpp:9010:21: note: in expansion of macro 'SERIAL_EM' case_light_on ? SERIAL_EM("on") : SERIAL_EM("off"); ^ sketch\src\../src/HAL/HAL_DUE/communication.h:113:45: error: expected ';' before 'do' #define SERIAL_EM(msg) do{ SERIAL_M(msg); SERIAL_E; }while(0) ^ sketch\src\MK_Main.cpp:9010:21: note: in expansion of macro 'SERIAL_EM' case_light_on ? SERIAL_EM("on") : SERIAL_EM("off"); ^ sketch\src\MK_Main.cpp:9010:37: error: expected primary-expression before ':' token case_light_on ? SERIAL_EM("on") : SERIAL_EM("off"); ^ sketch\src\MK_Main.cpp:9010:37: error: expected ';' before ':' token exit status 1 Errore durante la compilazione per la scheda Arduino Due (Programming Port).
Re: MarlinKimbra su Stratasys June 23, 2017 12:16PM |
Re: MarlinKimbra su Stratasys June 23, 2017 12:18PM |
Re: MarlinKimbra su Stratasys June 23, 2017 12:26PM |
Re: MarlinKimbra su Stratasys June 23, 2017 02:29PM |
Re: MarlinKimbra su Stratasys June 23, 2017 02:33PM |
Re: MarlinKimbra su Stratasys June 23, 2017 03:33PM |
Re: MarlinKimbra su Stratasys June 23, 2017 04:37PM |
Re: MarlinKimbra su Stratasys June 23, 2017 05:09PM |
Re: MarlinKimbra su Stratasys June 23, 2017 05:42PM |
Re: MarlinKimbra su Stratasys June 23, 2017 06:41PM |
