vers. 4.3.23dev Errore compilazione June 30, 2017 04:06PM |
C:\Users\CARLO~1.CAR\AppData\Local\Temp\arduino_build_6725\sketch\src\eeprom\eeprom.cpp: In static member function 'static bool EEPROM:tore_Settings()': C:\Users\CARLO~1.CAR\AppData\Local\Temp\arduino_build_6725\sketch\src\eeprom\eeprom.cpp:365:28: error: 'class Planner' has no member named 'bed_level_matrix' EEPROM_WRITE(planner.bed_level_matrix); ^ C:\Users\CARLO~1.CAR\AppData\Local\Temp\arduino_build_6725\sketch\src\eeprom\eeprom.cpp:206:65: note: in definition of macro 'EEPROM_WRITE' #define EEPROM_WRITE(VAR) write_data(eeprom_index, (uint8_t*)&VAR, sizeof(VAR), &working_crc) ^ C:\Users\CARLO~1.CAR\AppData\Local\Temp\arduino_build_6725\sketch\src\eeprom\eeprom.cpp:365:28: error: 'class Planner' has no member named 'bed_level_matrix' EEPROM_WRITE(planner.bed_level_matrix); ^Cosa può essere ?
Re: vers. 4.3.23dev Errore compilazione June 30, 2017 04:31PM |
Re: vers. 4.3.23dev Errore compilazione June 30, 2017 04:54PM |
Re: vers. 4.3.23dev Errore compilazione July 02, 2017 05:53AM |
Re: vers. 4.3.23dev Errore compilazione July 02, 2017 08:16AM |
Re: vers. 4.3.23dev Errore compilazione July 02, 2017 08:26AM |
MagoKimbra
Stiamo al 4.3_24_dev!!!
